I've been using the "special" cable clamps, must be a term for them? That look like a conventional one but they don't actually clamp down on the live cable.
As I like to go down the road with my ATB weight not jerking on the switch, the last thing I do when tearing down is winch up until the ATB stops me, then I hit the defeat switch and come up another few inches, just enough to have slack in the chain from the weight to the switch. To secure the hook and ball I have a hand winch and strap on the front, that way when I set up I don't have to climb back out of the cab to unhook it after reeling out some slack, I loosen it first thing, before putting the outriggers out. The only problem with this setup, is if someone hooks me up and I don't see them do it, then I winch up into the ATB, I tear my winch strap off. No big deal, just 2" load binder strap, I carry spares. Since going to this way of securing the ball, EVERYONE now wants to hook me up, before, when I NEEDED them to do it, to save me a trip out of the cab and back, they NEVER did it!
This leaves the dead end of my wire rope inside the cast iron weight ATB, so I mouse (now there's a term....) the end first using heavy black tape used by well drillers for securing the wires to the drop pipe, then I go over the tape with good old aircraft safety wire, which is stainless. That holds up real well, and looks good also. It took me a while to figure out why I kept going through ATB switches, like a dummy I was going down the road with that weight working on the switch, nobody told me, I had to figure it out myself.
of a well,
