john deere 650g tc transmission problems
luc2121
ontario
i have a 1994 john deere 650g TC dozer and everything works fine except no 3rd gear in foward or reverse ? theres no grinding but you can hear something turning in there. is this a common problem ? anthing i should check ?
thanks
luc2121
ontario
does anyone have a pdf manual for this dozer ? with it i'm thinking i could get it figured out. thanks
mrfixit77845
texas
code f497
i called jd they said it meant exccessive pressure in fuel injection circuit i think that was the quote. all the injector pump rebuilders say they cant rebuild it or get the parts it is exclusive to jd and they want me to haul it 100 miles to replace the whole pump. im thinking there is maybe a restriction and i dont know where to look
buckfever
southwest pa
We had the same problem on our 555g. Also had a friend with the same machine and also did the same thing. Can't remeber what caused it but I do remeber my buddy saying that he was going to have to take the counter weights off and go threw the back of the trans to get to it. Man this bugs me just can't remeber what it was buddy did say it was a cheap fix just very time consuming.
pipeline mech
whitewater WI
Sounds like your 3rd gear clutch pack is out. You can at least look up parts manual on JD website to get a look at what you might need.You will probably have to purchase a service manual from JD.
luc2121
ontario
Ran it today for a while and every so often would try 3rd and all of a sudden it started working, takes a second to engage but its working now, and stopped dor lunch and tried after and took around 4 seconds to engage first time and shortly after was shifting fine. Going to change fluid tomorrow and filter. A regular trans hydraulic fluid fine ? Or something else ?
Thanks for helping
buckfever
southwest pa
You need to use a uni-track type fluid. The same stuff you put in the hydrolics. Napa's part number for 5 gallons is 85-405 ( i'v bought quite a bit of this stuff over the years). John deere calls it hy-gard but really you need to look to make sure it is j-20 approved.
