John Deere 450 issues
Discussion in 'Dozers' started by Seafarer12, Jul 7, 2010.
  1. Seafarer12
    Seafarer12 Member
    Jun 21, 2010
    10
    Austin TX
    Hey Guys,
    I am looking at a JD 450C dozer. Here is the problem with it.
    It is a power shift model. It started with the steering getting weak. Then it got to where it wouldn't pull in higher gears. Now it will barely move and the hydraulics are very slow. The owner said he did some checking and some people said it might be a charge pump. I am not sure. I have worked with tractors and trucks but not on tracked equipment. What would I be looking to fix it if I got it? It has about 500 hrs on an overhaul and 60% on the UC and a 6 way blade.
  2. OneWelder
    OneWelder Senior Member
    Apr 12, 2007
    483
    Derry, New Hampshire
    The blade should be a separate system from trans.
  3. d9gdon
    d9gdon Senior Member
    Feb 12, 2010
    1,148
    central texas
    I've had lots of experience running them, but I never could figure out their transmission. It's a lot different than Cat.
    That hydraulic system is separate from the transmission though, sounds like more than one problem.
    I'd say it's got worn steering clutches in the best case scenario causing the lack of steering and then not pulling in the higher gears.
    If the tranny has some bad clutch plates, that would cause it to slip in the higher gears and would be a lot more time and money to fix.
    I'd say you need to check trans pressures first to see if they're OK. I've got the service manual on it if I can scan something for you or look it up, I'd be glad to. Like I say, I've ran several but never worked on the transmissions or the steering clutches. I'm just thinking out loud.
    The lack of steering could be caused by the brakes being out of adjustment too, but can't tell from the info provided.
    Let me know if you need something out of the service manual.
  4. Seafarer12
    Seafarer12 Member
    Jun 21, 2010
    10
    Austin TX
    Thanks for the reply. I just am not sure if I want a crash course in JD dozers. The way it was relayed to me was there is a charge pump that feeds the steering, tranny and the main hydraulic pump. If that is the case I can believe it. I am just not sure if he knows what he is talking about. He is asking 5k for it. I just don't want a 5k chunk of iron that needs another 5k to be usable.
  5. FurakawaMatt
    FurakawaMatt Well-Known Member
    Dec 13, 2009
    169
    Arkansas
    Like the adult undergarment, it depends. If you can get a usable JD450 for $10K, that is a good price. Would not take much work to amortize the purchase/repair. At $40/hr that works out to 250 hours run time, or a little over 6 weeks.
    However if there is more things wrong to repair before it is a working machine that changes the economics of it. Or if the repair parts are unobtanium that changes things as well.
    BTW in my experience, no used small dozer in the $10-$15K range is without problems. If they are mechanically perfect they go for a bit more.
  6. Greg
    Greg Senior Member
    Jan 28, 2008
    1,175
    Excavating Contractor
    Wi
    If it is a John Deere 450C it is not a powershift. It has a four speed gear type transmission which has a shifting lever for selecting one through 4. A second shift lever is for high foreword, low foreword, low reverse and high reverse. There is a conventional disk type clutch in the system which is activated by the clutch pedal with the operator's foot. The high/low/foreword/reverse shuttle is a hydraulic type clutch separate from the standard clutch.
    To start it sounds like the steering clutches may need to be adjusted. (simple procedure)
    The clutch may also need adjusting. (simple procedure but harder than the steering clutches) Takes a pressure gauge to to the transmission clutch. Best to get a tech manual which will give the details to do both.
    If you have to go inside of the transmission and change the clutch good luck. These little bit--es are a real stinking nightmare to work on.
  7. Seafarer12
    Seafarer12 Member
    Jun 21, 2010
    10
    Austin TX
    Thanks, for the help. I think I am going to pass on it. I am in the middle of building my house and I have enough on my plate. I will just have to make do with my Massey 65 till something else comes along.
  8. td25c
    td25c Senior Member
    Feb 15, 2009
    3,723
    indiana
    Hi Seafarer12,It's been awile since I'v had a 450c tore apart but if memory serves me right there is a hydraulic valve on the clutch linkage that controls oil flow to the clutch packs in the power shift side of the transmission.There is an access port on top of the bell housing to adjust the valve.The valve could be bypassing oil if its not adjusted properly or it could just be bad,I dont know but it's a place to start looking.The way I remember on a 450c you partly depressed the clutch peddle to shift the "power shift" gears on the dozer and fully depressed the clutch to shift the maual side.When the clutch is partly depressed the hydraulic valve opens killing oil flow to the clutch packs.Good luck with it and that Massey 65 with a box blade will move allot of dirt:)
  9. stumpjumper83
    stumpjumper83 Senior Member
    Jan 13, 2007
    1,960
    Movin dirt
    Port Allegany, pa
    that aint too bad of a price for a 450c, up here in northern pa, 7500 starts and they seem to top out 15 - 16k
  10. Seafarer12
    Seafarer12 Member
    Jun 21, 2010
    10
    Austin TX
    I made a mistake it is a 450B
    Thanks for the information. I might write the guy. I am wondering if the pump is getting weak too since the blade is slow too. I imagine the pump isn't the easiest thing to change. I have found them for the 500 dollar range. I am just not sure where in the guts they are.
    This one is just so cheap because it will hardly move and with the economy in the tank nobody is real interested in it. The only ones I have seen close are Komatsu dozers. I saw a real nice 450 loader with a clamshell bucket and rippers in good shape but it was in the 15k range.
    The Massey is good. I have a Massey roll over box blade too. It is a real stout one. I haven't seen many new ones close to this one. I just need to do a lot of dirt work on my 31 acres and the Massey is a bit slow.
  11. stumpjumper83
    Jan 13, 2007
    1,960
    Movin dirt
    Port Allegany, pa
    450b's have dry clutches and require more attention than the c's with the wet clutches. On a c the hydraulic pump is up front on the motor down low, and doesn't look too bad to change. Before I ordered the pump thought, I'd change the hydraulic filters and change the hydraulic oil.
  12. tuney443
    tuney443 Senior Member
    Mar 19, 2006
    1,177
    Dutchess County,NY
    Some misinformation going on here.I've owned and operated a bunch of small JD dozers,still have a 450D.The transmission is NOT a ''power shift'',it's called a shuttle tranny and it comes with a reverser.You put the tranny in gears 1-4 and simply use the reverser to change direction.You only need the clutch pedal when changing gears,NOT when using the reverser.The beauty of the system is that you can shift direction ''on the fly'',without slowing down at all and like I said,without using the clutch pedal.
  13. td25c
    td25c Senior Member
    Feb 15, 2009
    3,723
    indiana
    JD 450 C Transmission
    One word of caution on shifting from forward to reverse "on the fly" without comming to a complete stop on a 450 C dozer.They have a weak spot on the transmission casting back at the pinion bearing housing.The chamferd edge that holds the bearing away from the ring gear is only about an 1/8 inch thick .My buddy found this out the hard way slamming the gear shift forward & backward.I got a call from him to pick up the 450 & fix it.We ended up installing a new transmission case.The Smaller JD dozers are built pretty much like a 4020 farm tractor with the transmission structurally holding the framework all togather.I'll put it this way...It aint a 15 minute job swapping a 450 tranny case.;)
  14. d9gdon
    Feb 12, 2010
    1,148
    central texas
    Trans housing
    Amen, I've seen 4 of them do that when I was around them 7-8 years ago. It ain't cheap to fix either. They're a fantastic spreading dozer, but don't overload them.
    You have to adjust that main clutch so it grabs well but doesn't slip. For contracting purposes, I got away from them because they have a lot more power than they have sturdiness, for lack of a better word. We stripped finals, blew trannys and twisted other stuff by doing stuff they weren't meant to do. I found the D4 Cats to be a lot better suited for our main function, which was clearing cedar trees.
  15. Greg
    Greg Senior Member
    Jan 28, 2008
    1,175
    Wi
    The pump on a 450C is a real bit-- to change as is everything on a 450C. They are the worst machine to work on I have ever seen. Even the Deere Dealer techs say so.
  16. td25c
    td25c Senior Member
    Feb 15, 2009
    3,723
    indiana
    I agree d9gdon & Greg:iagree The JD 450 dozers & highlift tractors worked great on the jobsite, but dang ......when they break down they are a son of a gun to work on.Not mechanic friendly at all:cussing You have to be thin & double jointed to reach in to the bowels of the 450 crawler:D When I swapped out the tranny case for my buddy there was more parts & hardware laying on the shop floor than was still on the 450 dozer,whewwweeee!We drank a little barley soda after that job:drinkup John Deere must have hired the Smurfs to assemble the 450's at the factory:D
  17. amunderdog
    amunderdog Senior Member
    Apr 24, 2009
    280
    Sunbright,TN
    I have two 450A track loaders trying to make one good machine.
    Is it just me or are John Deere parts hard to get.
    Somethings are available, other parts no one even wants to look for.
    And i agree with those here who believe the design was lacking.
    Both machines the Frame to bell housing spacers T23886 And Frame to bell housing bolts T21238 are all broken.
    Seems they decided to hang the motor - radiator - and that heavy nose piece off the bellhousing by those broken parts.
    I found a used set of the spacers but the special bolts are a dealer item.
    Anyone have a good deere dealer to recomend?
  18. td25c
    td25c Senior Member
    Feb 15, 2009
    3,723
    indiana
  19. Greg
    Greg Senior Member
    Jan 28, 2008
    1,175
    Wi
    Got a 450C track loader here. Can't say that anything about the whole damn machine impresses me. Can't say I think they are great around the job site as put by td25c. Lots of hydraulic leak problems. Is even a bit-- to change the oil filter. The list goes on and on and on.
    My advise is to buy a D3 or D4 if you are looking for a dozer.
  20. tuney443
    Mar 19, 2006
    1,177
    Dutchess County,NY
    There is absolutely no need for a complete stop,or even close to a full stop with the reverser.With all the small Deere dozers and 510B hoe Iv'e owned and own over the last 36 years,that's the only way I've run them.It's even in the owner's manual that there is no need to stop before changing direction.I've worked these rigs hard too and I've never had any tranny related problems.
