KyHeadhunter
Well, after about 5 or 6 hours of studying the wiring schematic for the hoe, I figured out a good test sequence and followed through with it. I figured out which wire in the main harness plug between the cab harness and engine harness and tested for signal to crank there. Had signal coming from the cab side, but no continuity between the engine side of the plug and the K1 starter relay. With the sheet metal I had already removed, I could see all but about 6" in the harness and everything looked good, but the tests don't lie. So I pulled the hood and air cleaner assembly out of the way and sure enough I found another chewed spot in the harness. Three wires were chewed in half in this spot and I was able to make proper repairs without having to pull the harness loose. I took a couple more pics and will post them up in a little while after I get all the sheet metal put back on. It will be real nice to finally get this thing out of my garage!....LOL!
