KyHeadhunter
Hello All, I am Jim. I am working on my neighbor's John Deere backhoe model 310D, serial# TO310DG813560. The hoe will not crank the when the key is turned, the alarm just sounds and the stop light comes on. The hoe will start and run just fine if you jump the solenoid on the starter, however. I am trying to diagnose the source of the electrical problem preventing the key from cranking the machine. Also, I know at this time, the alt is new (neighbor replaced it before I got involved) and key switch is also new.
I start at the beginning with a test light, and no power is going to the solenoid from the key switch to signal the starter to crank, so I start checking fuses. The MFWD/ALT fuse is blown and blows a new one immediately upon making contact. Its obvious that the wire, labled P13, is shorted somewhere, but I can't find where it goes to. The harness in the dash has never been modified so it is still banded tightly together. Does anyone have a wiring schematic for this machine, or maybe have any idea where this wire runs to? Thanks, Jim.
