Walkerfarms
We have a JD 772, I did a water pump gasket on it. I also found that the belt was bad replaced the belt. After it ran for 5-6 hours the belt started to make nosie, I sprayed the idlers with wd40 found one bad replaced. 2 hours later same thing replaced the other two. Know it still makes nosie. I sprayed some belt dressing stuff on the belt it gose away for about 10 min then comes back. The alternator pully is good nothing changes when you spray that. Any ideas?
