Background: it's a 1986 JD 444c that used to be my fathers. He had health issues so it sat for 10+ years before I tried to get it going again. I spend last year getting the motor going. I finally did and used it a little. Now I hadn't started it in 6+ months because work has been busy.
When I went to change the hydraulic strainer last year (right after I got the machine started for the first time) it was completely disintegrated and pieces of mesh and plastic got through the system. Here's a link of the post I made showing a picture of it : https://www.heavyequipmentforums.com/threads/jd-444-suction-strainer-part-number.56273/
I used it for probably 10 hours the last time it ran. The hydraulics worked but they were never as smooth as they should be. They would be a little jerky at times like something was holding the pressure up.
The other day I went to start it to move it and the hydraulics didn't want to work at all. The only way to get the bucket up was to rev the engine and keep pulling back on the boom lever. When the boom would move it would come up about an inch at a time. Same with bucket curling back. The boom down and bucket curl down work perfectly.
Now I'm not doubting there is crap in the system but I find it strange the hydraulics did work the last time I used it. And after a 6 month park they don't want to at all.
Here's the thing. The machine needs a new engine. I've got what I believe stuck stick rings on one cylinder and a hanging valve on another and it's got very little power. I had planned to get a new (used) engine and put it in as a project. But if it's going to have major hydraulic issues I may rethink that. Any suggestions what my issue could be?
