JD 4045 w HPCR - wet fuel in all cylinder - will not run
Discussion in 'Generators/Gensets' started by 03hdrk, Aug 29, 2015.
  1. rmllarue91
    rmllarue91 Senior Member
    Apr 17, 2014
    303
    field technician
    northeast pa
    I'd reinstalling injectors and check for power to injectors if you get power to injectors ecm is probably fine. Did you check lift pump pressure I see small engines frequently that get enough fuel to open injectors but not enough to run. On an engine of this size I doubt its compression.... Are you trying to start with exh. Manifold off ? I'm sure that would rule out egr valve even if it's in intake.
  2. delly
    delly Member
    Mar 8, 2012
    8
    edam
    I actually just changed transducer and seems like fuel shutoff solenoid isn’t working I hot wired it and engine took off to 2000 rpm
    DB2 likes this.
