Rogermarineguy
1984 JCB 930 forklift will not charge battery,I did a replacement of the battery and checked the charging rate and has not move from 12.50 volts.i have full fielded the alt and it failed so I put a replacement on this morning with no change,the rebuilder said the original was faulty and if this one doesn't charge then try an additional external ground which I did but no change. I did find a Jcb tele with a similar problem to check the charging indicator circuit which checks the small brown/black tracer wire and I found I had 1.45 volts at the alt with key on and engine running,but 2.15 volts at the indicator lamp???. Without a wiring diagram, is one available? Or is something else on this circuit? Any ideas would be appreciated,thank you roger
