ether works great for mounting tires..again not an approved method , but when out in the woods and not left with much choice , it will get the tires sealed back on the rim, just stand back and out of the way incase it blows the bead off the rim...
You guys talking about ether washing down the cylinder walls? how much are you using? I've got a deere that'll start without it but I'm leery of long cranking times tearing up the starter. Near 0F, a one second shot into the outer air cleaner will have the engine running in four seconds of cranking, I'll usually crank for 3 and then give it a whiff, then 4-5 more and it'll start up as gentle as pie. No banging knocking or rattling. It runs out of that 1 second of ether after five seconds of running but by then its already fired up on all six. It just complains for another ten seconds. Without the gas its a minute or two of cranking with some partial starting before it'll hold on its own, then another 10-20 seconds of smoking like crazy before it smooths out.
Last week I needed to move some snow around with the grader. Plugged in the block heater and returned to start it when I discovered the block was still cold. After 12 years the 2000W block heater had failed. Not wanting to put the ether to it right away, (tempertures was right around zero F), I went into town to buy a new heater and ran into a old farmer friend. He said that he had used WB-40 on his JD machines instead of ether. His thinking was it supplied some lubrication. I ended up using ether as I was not in the mood to to clamp off cold hoses for the replacement and I was concerned about WD-40 messing up my paper air filters.
Any thoughts on using WD-40 instead of ether?
Agree. Always works for me. Don't need ether.Yair . . .
I have never had to contend with the cold some of the folks here speak of but I always felt the gasoline soaked rag in the inlet or around the pre cleaner was as effective as a spray can and (to me) the engines sounded happier without that ether rattle.
Cheers.
Perkins thermo-start burns diesel in the intake and works really well. For really cold weather like -30 and below some Perkins will use an optional ether injection system.
