hi to all members having problem with my roller replace vibrating pump after roller stop vibrating also took drum out an check parts inside all is good change drum vibrating motor an it start to vibrate at both hi an low ,after a short while it stop giving a strong vibrate an will only shake the drum replace the vibrating pump a second time it did the same ting work for a short time an gone back to a light shake, check the pump charge pressure with no load 300psi an with load it goes down to under a 100psi also replace filters an getting a good voltage to the high an low solenoid don't what to check again two pumps cant go bad just like that need some help with this one .
