watglen
- Joined
- Apr 3, 2009
- Messages
- 1,324
- Location
- Dunnville, Ontario, Canada
- Occupation
- Farmer, drainage and excavating contractor, Farm d
I have a lot of heated floors around here in barns and shops. Houses too.
As far as the shop floor goes most of the guys on here are telling you the same thing. Dig down around the perimeter and install styrofoam board. That helps prevent the heat from escaping out around the edges of the slab.
For your kind of loads i would go heavy in the truck bay, 10" sounds about right. The rest is good at 4-6"
Under the slab i like double bubble, the foil covered bubble wrap. You should check the engineering for that stuff cuz under concrete there is an up and a down. Along with providing a heat break, it also creates an impermeable moisture barrier. Keeping the moisture from coming up through the floor helps as much as anything to create a warm dry floor. I put a minimum of super 6 poly under all concrete to keep the moisture out. Also it keeps the moisture in the slab during curing, which enhances its strength. You definitely want that.
( here is a an aside: Around here they build barns out of a product called royal wall. Its a pvc wall structure that snaps and slides together to form a hollow pvc wall. The insulation is already in the panel, you slide the rebar into voids, and vibrate the whole thing full of concrete from above. You end up with a wall that is pvc on both sides, insulated, and reinforced concrete throughout. The important part is this, because the concrete is encased in PVC it cures really really really slowly. The water stays in place for months. Try to drill a hole in the wall after that. You can destroy carbide bits like butter. Its the toughest hardest nastiest glass-like concrete you'll ever see. I've heard of test results as high as 50kpsi from a 3500psi mix.)
Long story short, you want to keep the water in the concrete as long as you can. So you need to put some kind of plastic under it. I use double bubble and tape the joints.
After that, the most important thing is rebar, lots of it. Way too many people skimp on rebar, and the is about the dumbest thing you can do. Concrete contractors hate the stuff for some reason, they never want to put it in, so they tell you not to put much in.
For your floor i would lay 2 lifts 20mm bar on 1' centers both ways minimum. I may even go to a full 1" bar under the truck bay. I would cut wood blocks 2" tall, and lift set the bottom layer on them. Use blocks or stakes to place the second layer about 3" down from the top of the slab. Tie 1/2 ipex to the bottom layer, on 1' centers around the perimeter, 2' centers everywhere else.
You should likely pump the concrete on a floor that size, it will save a lot of trouble keeping all that rebar from collapsing ect.
Under the door area, and anywhere that you have heavy traffic, dig down a bit deeper, maybe 16-18" the thicken the slab. Create a rebar beam and place it in the void. This will prevent cracking around the door area. If the floor is raised a bit (and it should be) a tracked vehicle will teeter at the threshold, and you know what happens next. The extra thickness will prevent cracking.
Depending on your drainage conditions you may or may not want 3/4 clear under the slab. If you have good drainage, you don't need it. Make sure you are virgin soil, not fill. If you have to raise the elevation, then you need it. If you use the gravel, you need a way to remove water from that layer, like a sump pump if nothing else. Also, you will want someplace to go with your sink drain or whatever, a sump pump works good for that.
Set your final elevation as high as possible, cuz in 15 years it'll be too low (for good drainage). Driveways always come up, floors always go down.
After the concrete is in and setup enough to walk on, lay super 6 on it and leave it for as long as you can. A week or more is great, the longer the better. That will help create some super tough concrete.
Sorry for the length on this post. There's lots to concrete floors. You only get one chance to screw it up.
What are you going to use for a heat source? I just installed a 250,000 btu tankless water heater in my barn, and it works great. Im really impressed with it, and i think my gas bill is going to be much nicer.
Good luck.
Good luck.
