crane operator
1987 p&H t650 (crane). Detroit 6v92.and 13speed trans. Has a hydraulic clutch with air assist. Depressing clutch have no air assist, and I'm dumping air out clear at the back of the crane at a brake valve.
I'm guessing I've lost the air diaphragm in the air assist, and that it exhausts out through the brake valve. The only part # on the slave is 642-03120 then JKC under that. I've also lost the bolt in the rear of the chamber for the diaphragm, I'm wondering if it captures a internal spring.
Anyone identify what its from in the pictures. I'm going to try to limp it home this afternoon from a jobsite without the air assist, and then remove it. I'm hoping someone says "that's from a early 80's mack", not - "gee I've never seen one like that".
Possible to make a diaphram? tire tube or brake pod rubber?
I'm not even opposed to making a mount for a different style- I've just got to get something in it.
