How stupid is this
hetkind
Unicoi, TN
2 years ago we had 5000gal of acetone go up when the guy filling it left his phone in his pocket and got a call. I saw the security footage...you've never seen fire until you see a fire like that.
Acetone has been quite the problem, very low flash point, low initiation energy, high vapor pressure. I have seen acetone vapor set off by rubbing nomex coveralls on plexiglass. As a teenager, I used to use acetone in my zippo lighter since I had a free supply from my father's medical laboratory.
Howard
Here's a regulation few know about. FMVS rule that all commercial vehicles with air brakes have the air tanks tested once a year. At 500 psi for 10 minutes.
First where am I going to find 500 psi air pressure to test with. Have any of you folks ever seen anyone do a yearly test on truck air tanks? Not to mention
I wouldn't want to be anywhere near a truck air tank at 500 psi.
hetkind
Unicoi, TN
That is an easy one...call up your gas supplier and get a tank of nitrogen and two stage regulator that goes to five hundred psi. Then test while on the other side of a reinforced concrete wall, like they do split rims behind.
Howard
Dozerboy
TX
Operator
No way I got scared then the regulator when out and I hit 200psi on my way to the shop.
RZucker
Wherever I end up
Mechanic/welder
That's a test that shoulb done with water, similar to a hydrotest for boilers. Water doesn't compress and release energy like bomb if the vessel ruptures. You'll just get wet.:D
kshansen
Central New York, USA
Gee I thought the test was to empty a can of starting fluid into the tank then hold your ciggy lighter next to the inlet!
And yes the test calls for a hydro static test. But I guess the point I was making is no one does an annual test.
S5.1.2.2Each reservoir shall be capable of withstanding an internal hydrostatic pressure of five times the compressor cutout pressure or 500 psi, whichever is greater, for 10 minutes.
Howard
Yah there is always an easy way. Just do this and that never mind money and time wasted. It's just a silly a$$ regulation.
fixou812
Buffalo NY
Millwright Equipment Mechanic Welder
I used to add 2/3 oz. Of acetone to every 5 gallons of gasoline Made it run Real good and better milage.
Howard
Heavey Metal
Texas
Howard
Typical dum as safety engineer
The most dangerous person on the job.
hetkind
Unicoi, TN
Let me help you out with that...I think you wanted to say "dumb ass" and we all have rights to our opinion. We all know guys who ended in safety because they screwed every OTHER job up. When I was young I had bosses like that, later I was given teammates like that, now, that I am older and wiser, I can find them good homes where they can do little damage.
But if we go back, the original question was "how do you test at 500 psi" NOT "should you test at 500 psi"
The ASME pressure vessel code allows a air test when a hydrostatic could contaminate the system, and they require shielding for possible primary and secondary fragments. The split rim shops around here have a separate bay with a good reinforced concrete wall the operator stands behind to inflate instead of a cage. This would contain the possible fragments if the air tank let go.
I look at test plans for high explosives on a weekly basis and know exactly what high energy fragments will do. It takes a good chunk of high explosives to generate 500 psi at 20 feet.
Howard
td25c
indiana
Never heard of that one Truck Shop , I imagine if everyone tested trucks & equipment to that PSI it would stimulate air tank & related component sales . LOL!:D
Heavey Metal
Texas
Howard
Come on dude face it that was really bad advice for you to tell someone to put 500 psi of nitrogen in an air tank.
But than anyone with a lick of sence knows it would be hydrostatic.
hetkind
Unicoi, TN
If I told someone to PUT 500 psi in a air tank with a hydrostatic test requirement, I would be wrong. What I said was getting the 500 psi air to put in was the easy part...
However, not going to wrestle with pig, you both the get dirty and pig enjoys it.
Howard
I never intended to test any air tanks. And FMVS has changed it's rules about testing annually on commercial vehicles. I can't find the rule
on that, It had been around for years. I know it was there two years ago. My point was there test improperly done would lead to more
people being injured.
The FMVS only changed the requirements on the material and strength testing of trailer kingpins five years ago. It had been the same for
75 plus years.
hetkind
Unicoi, TN
75 plus years.
Sometimes the cure is worse than the disease...I can see that a hydrostatic test improperly done would fill the system with water, and then have it freeze solid in cold weather. I would think that removing the air tank to be tested by a specialty vendor would be expensive. On the other hand, how would you find internal corrosion that would affect the overall strength? Since I am not in the trucking industry, I haven't read the FMVS.
Howard
Howard
Heavey Metal
Texas
Howard
Please refer to post # 23 this thread.
Heavey Metal
Texas
Howard
Howard
Sence you have no knowledge of this subject please refrain from giving dangerous advice.
Here is the proper procedure which includes measuring the amount that the tank swells
https://www.google.com/url?sa=t&sou...oiwr00TId-9RVu1kA&sig2=pSC5rvBrvbro4LEwJSCgMw
kshansen
Maybe I am missing it but I do not see in the link posted that this is to be a "once a year" test as the poster in #22 said it was. What I did read in the link was:
NOTE: Since this test is potentially a destructive test, proper safety
precautions should be observed. Consult the COTR for disposition of test
reservoirs. Proper shielding of the test reservoir is recommended in the
event the reservoir should rupture during the test. Under no
circumstances should the tested reservoirs be placed in service on a
vehicle.
The bolding and under line is my addition!
hetkind
Unicoi, TN
Now it makes sense...this is a design verification test, and has nothing to do with normal vehicle maintenance.
All this noise about something that occurs in a testing laboratory to certify the design of a braking system.
Howard
