Dzr looks tidy nitelite
Looks to be on 18" shoes too that will make it a lot better in softer ground and more stable too. Don,t know why someone has welded abit of bar on the drum for the rope ??? Be a pain to try and wind rope on properly. Once ropes on one wind and tight ferrule won,t come out.
Yep that's the cover to adjust brakes, I just an,t too sure you,ll get in there to adjust the brakes. If you get cover off look inside and you will see adjuster nut. Yes your mates right about removing seat then cover under seat and you will see the cover I talked about earlier. [its above the small cover in your pic also] So is 2 different holes you can get access through to adjust brakes. Top hole is also for adjusting steering clutchs.
Before you get too keen on pushing dirt; go over the machine and check all the fluid levels; even change them and the filters if you don,t know how old everything is. Definetly do fuel filter if nothing else; most U.S. dozers had what cat called a sleeve metering fuel pump and they are very expensive to repair if they get water in them [ and they don,t need much water either] the earlier scroll pump was much better. Also final drives can be weak if not looked after [both in $ and time and work to repair] Get that lubrication and maintence guide.
Winch is a Hyster D4E very robust and strong. Don,t run anything lighter than 3/4 rope will snap anything less without too much effort, plus bigger rope spools a lot easier. Won,t be any info about it in the cat book, But you can download a book for free from Allied winch [they bought hyster] look under early manuels.
cheers merv :drinkup
