I still have some electrical problems on this machine. After the problems in the posts above, I decided to replace all wiring on the lights. So now the lights are connected directly to the battery with a separate fuse and switch. And no longer to the fusebox inside the cab. I also replaced the grounds that were connected on each lights bracket, and made a new cable connected to the main ground behind the batteries. Now i can run all lightning, wiper, and heater together with out problems, as long as there is power on the batteries.
But the batteries are not charging, so i think maybe i have to replace the alternator.
Does anyone know wat kind of alternator that is fitted on this machine? Maybe someone has a part number i can use to find it?
Also i would need a tip how to meassure if the alternator is broken or not. Where can i connect the multimeter to check this? (As you see i'm not really an electrical genius...)
