DRC65
I'm hoping from some guidance about the best way to identify where my leak is coming from
It's an EX60-1 and I noticed oil spilling out of the ring gear. Pretty certain it's hydraulic and the level of hydraulic oil has dropped. There's no oil on the top side of the structure around the swing motor or centre joint and none of the pipes appear to be leaking. Swing motor gearbox oil level appears correct (although thinner oil than I expected).
I slid underneath and there is a coating of oil over the bottom of the centre joint. I took the small plate off the bottom of the undercarriage that accesses the void inside the slew ring and drained out about 5 litres of water (!) followed by 10 litres of hydraulic oil. Once empty I could see up inside with a mirror but no obvious sources of the leak.
When the engine is running there is a steady trickle of hydraulic oil from this opening but I can't see where it's coming from. Everything operates correctly but there's no change in the rate of oil leaking when I use any of the hydraulic circuits (incl slew, blade or tracks).
Any guidance that you can suggest to help point me in the right direction would be much appreciated.
