Hitachi ex120-2 adjusters
Discussion in 'Excavators' started by metro, Apr 20, 2010.
  1. metro
    metro Member
    Apr 19, 2010
    5
    australia
    Does anyone know how to pull apart the idler wheel adjuster assembly on a Hitachi EX 120-2 so we can replace the seals? We have the assembly out of the machine but cannot seem to move/undo the rod nut. Is the assembly under tension from the coil spring?
    I look forward to any helpful response.
  2. willie59
    willie59 Super Moderator
    Dec 21, 2008
    11,586
    Service Manager
    Knoxville TN
    Whoa nelly! Rod nut? On the track adjuster? If your talking about a big nut on the very back of the removed adjuster assembly...do not take that nut loose! Yes that assembly is loaded by a very big stiff spring. You should be able to simple pull the chrome adjuster rod out of the housing. You should find a u-cup seal on the end of the chrome rod when you pull it out.
  3. cps
    cps Senior Member
    Jul 13, 2008
    806
    plant mechanic
    Ireland
    :iagreeYea what atco said, only he took the time to write it:D
  4. metro
    metro Member
    Apr 19, 2010
    5
    australia
    Yeah, thought that would be the case - have since removed the rod and replaced the seals - all good.
    Thanks for your valuable input.
