Tyler8400
Does anyone have and advice on fixing high shoulders with a gravel reclamation disc on gravel roads.
Our township uses a shoulder reclaimer with good success, we pull it with a tractor. We try to do our reclaiming early in the spring after things have dried up and before the grass has gotten a chance to get too tall. The sod chunks are your worst enemy, if we encounter allot of sod, we pull both sides in to the center of the road and hit it with a small 3 point disc to help chop the sod. You will gain some binder in your gravel by doing this. The reclaimer is designed to cut the shoulder sod in narrow ribbons so it is more manageable, once adjusted right. Speed is also important seems like it works best at 8 to 10 mph, tends to throw sod & material further into the road, & starts drying faster. After a couple passes (or whatever it takes) your shoulders will be much improved and you can establish better crown. After the first treatment you can go back in a couple of years & hit them again, this time it wont take as much effort. (The first time is the worst) Good LuckDoes anyone have and advice on fixing high shoulders with a gravel reclamation disc on gravel roads.
We will for sure run the reclaimer on a stretch of road before getting new gravel. The rest of the roads I guess you could say as needed. Keep an eye out for a used reclaimer I have seen them for sale on occasion.Thanks for the tips vernier and awesome pictures Cat140MAWD. Is this something you guys try to do every spring across the whole township or just as needed. Trying to get my township talked into getting one.
I'm just starting to disc my shoulders in today will post pictures tonight when I get done with workFollowing this thread. None of the local townships have one. But the State has one they use repairing wide gravel shoulders on paved roads.
Post some pics when you guys get a chance. Thanks!!
Yep we pull it right up on to the road it looks like there's a lot of dirt in there but there's not we recover a lot of gravel also doing this plus doesn't hurt to get a little dirt mixed in with it makes gravel hold together a lot better and improves drainage here's pictures of road after I've pulled it all inYou actually pull that dirt into the road ? Just curious .
