Yes it is already to go I just have to put the old cylinder back in and with new seals at the idler end and it should be ready, the only problem I have at moment is I have managed to break one of the bolts on the stopper and I would say the other bolt will probably break too when I go put any decent pressure on it.I have it all soaking in mixture of diesel and Onerex think that is how you spell it supposed be penetrating lubricant etc but nothing seems to be loosening up as of yet.Opps......I see my post was a little late. Already compressed!
No Scott nc everything was all hosed out with high pressure water spray most people over in Oz as far as I am aware call them a Gernie ,I do anyway.I had already taken side arm going to the idler off as well as making sure there was no pressure from any grease was all released.In other words the adjuster shaft was just sitting there.Such a shame because there was only 2 things really wrong with the whole assembly and that was the braces at back were all rusted which meant to take the pressure off the spring was to tighten the big nut on the end but the thread was all rusted out as well and it just couldn't be done that way. Doesn't really show up in the pics too well but the base where the spring sits up against had to be all straightened back to where it should be before I could start welding the new braces in.I am late to the show. Having a D4D and having had the track adjusters apart I couldn't help but notice something in the first set of photos; the adjuster was fully extended while cutting the tension spring coils. There is a good 4-5" of adjuster shaft showing behind the head of the adjuster where the grease fittings reside. Mine would not collapse due to dirt build up which may be the case here.
Yes I have had trouble in the past what I did this time was made up a mechanical adjuster out of pipe and a large nut and bolt and pushed the idler to somewhere near where it would normally run and put a G clamp on the frame. Obviously I had the luxury of being right next to my so called workshop and it would not have been as simple out as you say out in the boonies. Been there and done that one in the past not easy.Ahh, missed that part. Curious, I too pulled the outer half of the wishbones; How much fun did you have getting the bolt holes to line up for reassembly? Put my problem was that I was alone, out in the boonies with minimal tools.
Thank you DMiller yes not perfect but very happy with how it has come up have got a video of it working but it is apparently to big to display on this site. However here is the tree, big old dead ironbark that was right beside our driveway, first pic is of the tree on the ground, second where I covered up the hole that it left. The tree just came out easy as.Too Purdy to use!! Should work very well!
