mattwaage1
Hi all!
Well thanks to everyones good advice i abandoned the case 9050b from the earlier post and found a well loved but decent john deere 992elc.
It starts and runs, i loaded it and took it home already. It was a big bigger than i wanted but the price was great as i got it for almost free.
Its sat for a while and i have started replacing hoses and it needs a hydraulic cooler, the one is rusted and has holes. I bypassed it for now.
Anyhow, heres the few questions i have.
The former owner states that the machine was parked due to some slow hydraulic performance.
With a bit of testing it appears to me that swing is very slow and left track seems underpowered also. I have read aboit being able to do some testing on the pump solenoids? Any advice where to start?
Second, the electric throttle has been replaced with a push pull type cable. The factory electric control is not around now so i dont even know what the parts are to replace.
1: is the electric throttle needed? Does it provide input to the pump computer or anything that would cause slow performance or am i ok just using a throttle cable and not having the work modes or auto idle?
2: anyone have a picture of the electric throttle so i can see what parts i am missing and price them out?
The hydraulic cooler is trashed on this unit and bypassed to run it on and off the trailer. I have a line on some new ones for about $1100 delivered. Any better options?
I am looking to run a mulching head on this that will run about 100gpm so i would like to order 2 and install them to make sure the oil does not overheat from this load.
Last question for now: i would like to add a thumb to use also. Any way to run a hydraulic thumb and the hydraulic mulcher head at the same time? Or am i better off with price and simplicity with just a mechanical thumb? This will be used for vegatation and forestry so being able to handle and control brush and trees would be handy.
I heard there is a way to change the auxilary hydraulics from one way to 2 way quickly on these.models?
Im sure i will have a few more questions in the future but thanks for everything now! Ill add to this as i get things figured out and solved!
