I have a picture of the pump but can't seem to figure out how to post it.
I'll try to explain that much. First save the picture to some place easy to find it on your computer, I use Desktop.
At the top of the box where you enter the text for your message there is a row of icons at the top the second from the right, circled in red here:
Click on that icon and a box should open up at the top of that there are two tabs. one says "from computer" the other "from url" click on the "from computer" tab. New box should show up at the bottom of that one is a box "Select Files" click on that and it will take you to what I call "file manager" on you computer where you can locate your file with the picture. Click on the file name and it should show up in the box(the name, not the picture itself). Now at the bottom of the box it should say "Upload Files" click on that. Now in the text box where you were typing the message you wanted to attach a picture to you should see something that looks like "{attach]192818[/attach**" that is you picture you will not actually see it till you click on the "post quick reply" to post the message. Sounds very complicated but do it a few times and it is very fast and easy.
Just a note, when I first tried to post this It came through a little off as when I used the [ at the start and then the ] at the end of the description of what you see the forum got confused so I changed them to ** and **. I'll see if this works better.
Well that did not work either but hope it still makes sense!
