digger242j
Another "just curious" question that came to mind...
Have you in the course of your work, unexpectedly run into any "hazardous material"? If so, was it handled properly?
Obviously, HAZMAT items come in many forms. Abandoned storage tanks, even though empty, can no longer simply be dug up and hauled away. There's plenty of old roofing shingles that contain asbestos, and they might turn up anywhere there was once a building. Then there's goodness knows what else buried out there that's even worse.
Two instances of which I have personal knowledge...
I personally know of one storage tank that's still in the ground because it wasn't quite in the way of the work being done. It's got to be between 50 and 75 years old by now, and although I can't say for sure, I think it's probably about a 1000 gallon tank that once held gasoline. By rights, it should've been removed when it was found, but it wasn't, and that was at a time (20+ years ago) that it would've been a lot less carefully regulated and watched than today.
It wasn't a job that involved heavy equipment, but about that long ago I was asked to remove some heating pipe from the basement of a building. It was wrapped with insulation. I was suspicious about what excatly the insulating material was, so I asked. I was assured that it wasn't asbestos--all the asbestos had been removed from the building. I wasn't convinced, so I took a sample to a lab and confirmed that I was right--it was asbestos. Further discussion revealed that the owner had understood that it had all been removed, when the fact was that it had been "either removed or encapsulated". That's quite a difference, when you start ripping into that old piping. We left it alone.
