Installed an Enginaire VLR lid on an SVL75-2. Had to bend a fuse panel holder, elongate the filter can bracket holes (to lower the housing), adjust the top radiator hose to fit the radiator at an angle, and, still had to trim a bit of the lid inlet fins, as it was too close to the top radiator hose. Also, had to reclock the VLR lid, by removing the 5 screws on the VLR end cap and turning one hole counterclockwise.
It's close, but it can be removed without tools, or tilting the radiator. Clearly, the other suggestions are from well intended people, but, they obviously don't have a "10lb of **** in a 5lb can machine".
I also fitted a stanadyne fm-100 separator assembly in place of the factory "water" separator in the fuel supply side.
And, installed the Kubota rear vision camera system.
As an aside, if you have an SVL75, inspect the longitudinal bracket under the muffler. Mine was sheared at both ends (2300hrs). The muffler outlet was melting the AC hoses that it was resting on, and the muffler inlet pipe was sheared. Kubota tech says that's a first. I welded and reinforced both ends of the bracket, and patched the muffler inlet pipe.
