DelVin
I acquired a neighbors ’98 Bobcat 325 Mini-X over a year ago. Everything works perfectly. So last week, I finally purchased and installed a thumb I’ve been wanting. I pressed the left foot pedal and the thumb goes one direction. I can press the pedal the other direction and pressure is released from the line (so I can push it back with the bucket [or use gravity]). This is the older Bobcat, with no visible electronic/hand switch. I tried moving the lever by the left ankle (believe this is the auxiliary mode selector) both directions, but the results are the same. Could anyone tell me if there is more involved in switching from Hammer to Thumb mode than just moving this lever? i.e. engine running or not, etc….. If it's supposed to be that simple, how would I diagnose and correct this issue? Could someone share the theory of operation of this lever and it's interoperation with the auxiliary circuit?
