Davvinciman
- Joined
- Nov 29, 2011
- Messages
- 82
- Location
- So. California
- Occupation
- Operating engineer and business owner
This book covers the basics of grade checking up to the most advanced techniques for checking slopes, estimating elevations and distances from remote references, calculating yardage and measuring without a tape. You can do this with three pieces of equipment that will replace half the tools on your grade checking belt.
Too good to be true? Everyone I ever showed this to wanted to know how I came up with this. I have been using this method for years and it is absolutely accurate. If you can shoot a hand level, you can use a clinometer and more accurate than up4, out8. You'll never have to get out on the slope to check the grade for a dozer. Save your energy and your ankles.
I used this system when we all had to use tapes but with the laser measuring device (LMD) being about a hundred bucks, this technique is off the map. Use landmarks, telephone poles, the tops of trees or buildings, figure elevations and distance using totally inaccessible reference grades.
If this sounds like something you are interested in, look me up at:
www.gradecheckingpress.com.
