willie59
Well, good thing about those type ignition coils, even if it turns out coil wasn't problem, it didn't cost you a pile of money to find out.
Could be power relay 1 (PR1) sticking, or time delay relay 2 (TR2) is faulty. Try switch PR1 with PR3 (aux power relay), and switch TR2 with TR1 (traction delay relay) and see if it does it again.
If it jumped up to full throttle then the actuator is probably ok.
The test was to put 12 volts across the two wires on the actuator (without the engine running). If it snaps wide open then it is good.
Check that it moves smoothly throughout the full range of motion and that the return spring has a healthy pull back.
Testing the governor (black-box) is a simple procedure also, if you are willing to take a stab at it.
