Ford LRG - 425 starting problem
Discussion in 'Other Construction/Demolition Equipment' started by CharlieVT, Jun 15, 2017.
  1. DavidL
    DavidL Active Member
    Jun 26, 2017
    32
    Michigan
    Mine doesn't have a map...parts diagram doesn't call for one. I thought that might be part of the ECU retrofit kit.
  2. Birken Vogt
    Birken Vogt Charter Member
    Nov 30, 2003
    1,277
    Grass Valley, Ca
    On the generator engines I work on I see the tube for the MAP but have never seen one hooked up so they either just use the same body for the ignition controller without MAP installed or they just run it fully retarded all the time, with the timing fixed.
  3. DavidL
    Jun 26, 2017
    32
    Michigan
    According to my manual...the timing is adjusted by engine temp and rpm alone (from memory).
  4. CharlieVT
    CharlieVT Member
    Oct 23, 2014
    16
    New England
    Okay Gents,
    My ignition problem solved. Thanks for the replies and suggestions.
    Picture of the old ignition module I removed, not easy to see in this pic, but partly hidden from view is the nipple for connecting vacuum hose, so the "MAP" was built into this unit. (I hadn't thought of this vacuum connection as a MAP sensor) : ManliftOldESC.JPG
    This one module was replaced by three items, new spark control module, a stand-alone unit for the vacuum connection, and wiring harness that connected to these new units, the original wiring harness connector for the module that was removed, and a new connector to the crankshaft position sensor.
    The original wiring harness connector for the crankshaft position sensor was unplugged and taped off, unused.
    There was one unused connector on the new wiring harness. I suspect this harness is used for both carbureted (as mine is), and fuel injected versions of this engine. I suspect that this one unused connector would be used to connect to fuel injection circuitry in the case of a fuel injected engine.
    Picture of the new components: ManliftNewESC.JPG
    The parts came without any installation instructions, but the Gentleman at Powertech Engines told me about the need to connect to the crankshaft position sensor and disconnect the original wiring, and that there would be an unused connector on the harness. With that info, it was easy to match up all the other connectors.
    Again, thanks for the suggestions.
    Hope my post helps someone in the future with similar problem.
    thepumpguysc likes this.
  5. thepumpguysc
    thepumpguysc Senior Member
    Mar 18, 2010
    2,076
    Master IP rebuilder
    Sunny South Carolina
    Very good & informative post.. thank you for coming back & telling us what you found & what solved the issue..
