oldhousehugger
As I remember it was a 5/16 grade 8 allen head with a lock nut. Be careful that it does not interfere with the drive shaft. I tried lapping out the inside hole in the pitman arm so I could insert a bushing but that was way to hard. Then I figured that the slop in the larger pin was acting like a limit switch just like the pin in the smaller socket. By reducing the travel of the pin in the socket you compensate a little for the wear in the larger main pivot. If you do the math it works. Also if you look at the ag version of this machine, that setup has a stop adjustment both ways. Why the heck didn't they do that here? This machine is just a beefed up agricultural tractor front end. The engine and drive line are the same.
Managers got tired of waiting probably!!!!
Also the adjustment is maddeningly finicky at the turnbuckle on the cylinder. Just keep fine tuning it. I finally got mine to work after several irritating trys.
