ford 3000 help
Discussion in 'Agricultural Equipment' started by Dualie, May 23, 2011.
  1. Dualie
    Dualie Senior Member
    Feb 24, 2007
    1,371
    Nor Cal
    I inherited a ford 3000 from a friend that was moving and didnt want to deal with it.
    The back story is his neighbor borrowed it and blew it up, neighbor found a good used engine and put it in. IT ran marginal for a while then started smoking and running rough and now it wont run at all.
    It was very low on fuel so i added 5 gallons to the tank. Bleed out the system all the way to the injectors. I get fuel squirting out of all the injectors but not with as much force as i would think there should be. also getting fuel all the way to the tank return from the IP.
    It spins over but doesn't even try to fire even with a "who cares at this point" shot of either.
    anyone know where i can get a compression checking adapter for the ford 3000?
    Im trying to save it from going to scrap but Its not making it easy on me. its very close to getting the torch.
    I have a tractor wrecker willing to give me $1200 for it but its probobly worth more than that as prepared scrap.
  2. funkinalive
    funkinalive Well-Known Member
    May 22, 2011
    95
    Student
    Europe
    not even firing? maybe a number of things, mind you i dont own a 3000 or a ford for that matter but,im guessing motors got no compression to ignite mixture. maybe also check for blockage in the air intake (rats nest) it the motor fairly easy to turn over?
  3. koldsteele
    koldsteele Well-Known Member
    Aug 20, 2010
    223
    Owner Heavy Equipment Mechanic
    Va.
    Hey Dualie ..I made one out of an old injector ...just gut the injector and thread a gauge on ....These motors where bad to blow the head gasket between two cylinders ..I'd just pull your injectors and spin it and I'll bet you'll find your troulbe ..Good luck.
  4. Richardjw~
    Richardjw~ Senior Member
    Apr 14, 2007
    305
    South Devon, U.K.
    I had a similar problem with my 3000 at home, it would only start with easy-start, anyway come the end it would only rev to about 1200 and lost all its power and was running on 2 cyls......turned out to be that rotary fuel pump, put a new one on it and its fine now....starts better as well
  5. Dualie
    Feb 24, 2007
    1,371
    Nor Cal
    Not even trying to cough and fire. intake is clear i can feel it trying to suck on the intake stroke. IM starting to suspect atleast a bad Injector pump. im trying to decide if its worth throwing a $700 Injection pump at...
  6. funkinalive
    May 22, 2011
    95
    Student
    Europe
    if its not even attempting to fire with ether or quick start sprayed into the intake tract than im not so sure you should jump to that conclusion just yet...
  7. Richardjw~
    Apr 14, 2007
    305
    South Devon, U.K.
    simple, take the fuel lines off the injectors & see if its delivering fuel......end of
  8. funkinalive
    May 22, 2011
    95
    Student
    Europe
    Dualie stated in his first post that he already did that
    "It was very low on fuel so i added 5 gallons to the tank. Bleed out the system all the way to the injectors. I get fuel squirting out of all the injectors but not with as much force as i would think there should be. also getting fuel all the way to the tank return from the IP."
    additionally, the tractor refuses to lite even with quick start, which should get the motor to cough, this in my book would indicate little or no compression...
    i maybe wrong but im leaning away from a fuel delivery issue based on whats been said.
  9. Richardjw~
    Apr 14, 2007
    305
    South Devon, U.K.
    OK, well let us know what you find Dualie because we're on the edge of our seats here
  10. grandkobelco
    grandkobelco Well-Known Member
    Mar 24, 2011
    232
    chainsaw, small engine mechanic
    lazy boy in a barn
    Dualie, can you pull one injector out of the head, and it's fuel line and reassemble them out were you can see the injector tip? Cranck the engine over and watch the injector tip. Stand back. This fuel is under high pressure and can be dangeress. If you get no spray at all the dellivary valve in your inj pump is probably bad.
  11. Willis Bushogin
    Willis Bushogin Senior Member
    Nov 7, 2007
    855
    owner
    NC
    Guess Ill hijack, this thread
    Im trying to help a neighbor, he has a Ford 3000 also, according to him he let someone borrow it and now the lift will not lift the box blade. It will lift it, if you rev the engine up and manually lift on the blade, but if you let it down, you have to manually help it back up.
    The tractor doesnt have a hydraulic filter and you can take the pressure line off and it apprears to have good pressure. Im really not a tractor person, I was told it might be the lift cylinder is bypassing. I looked at the service manual and it looks like a bad job to get to the cylinder
    I think the tractor has had a rough life, but Im just trying to help a friend
    Any suggestions
  12. smittysrepair
    smittysrepair Well-Known Member
    Dec 26, 2010
    88
    Technical Specialist
    Grimsley Tn.
    Will it hold the box blade up on its own after you get it up?
  13. Willis Bushogin
    Nov 7, 2007
    855
    owner
    NC
    yes it will stay up for like 10-12 hrs before it leaks back down to the ground
  14. smittysrepair
    Dec 26, 2010
    88
    Grimsley Tn.
    It's not the cylinder then. You need to get a pressure gauge on it and see what kind of pressure you actually have.
  15. Willis Bushogin
    Nov 7, 2007
    855
    owner
    NC
    now the big question, where to put the guages and what should it read
  16. smittysrepair
    Dec 26, 2010
    88
    Grimsley Tn.
    If I remember correctly there is a threaded port under the seat that you can check the pump pressure on. I am not sure what pressure it should be though. But I am digging through my library for your answer and I will let you know what I find.
  17. smittysrepair
    Dec 26, 2010
    88
    Grimsley Tn.
    I did find a spec sheet on a Ford 3000 tractor and it says hyd pump output is 4.8gpm and 2,500psi at 2,000rpm engine speed. Also I am almost positive on the test port being under the seat. Let me know what you figure out or if there is anything I can help you out with.
  18. Willis Bushogin
    Nov 7, 2007
    855
    owner
    NC
    Thanks, I will try to check it out in a few days
  19. mitch504
    mitch504 Senior Member
    Feb 27, 2010
    3,752
    Andrews SC
    That test port is on a small (about 5"x6") cover under the seat. In order to get a dead end test pressure you must take that cover off and reverse it. The test port is an o-ring boss fitting, bout a -4 or -6. If there is an aux. valve installed it will be in place of that cover, and you just use it.
  20. koldsteele
    Aug 20, 2010
    223
    Va.
    Willis I dont think you have pump trouble ...Its fairly common after time these lifts get out off adjustment ...The only thing is you have to take the lift cover off to do these adjustments ..Good luck..
