fixing thrown track on kubota
Discussion in 'Excavators' started by videoeic, Apr 17, 2008.
  1. videoeic
    videoeic Member
    Apr 17, 2008
    5
    NJ
    Yesterday I threw a rubber track on my Kubota 91-2,
    I'm trying to put it back on and removed the grease fitting and am trying to push the idler back but it wont budge.
    I have a heavy duty ratchet strap wrapped around the idler trying to move it, but nothing.
    Any suggestions?
    Thanks
    John
  2. humboldt deere
    humboldt deere Well-Known Member
    Mar 28, 2008
    223
    general building and engineering contractor
    N.california
    you have to remove the bolt that the zerk is in, lift the track off the ground and the weight of the track should run the idler back in. use a big bar to run the track on while some body slowly runs the track forward and it should jump back on.
  3. greywynd
    greywynd Well-Known Member
    Apr 25, 2005
    225
    Peterborough, Ontario
    Yes, the bolt the zerk is in acts like a check valve. It needs to be removed. I would suggest you release any extra tension on the idler when you do it, or you may end up wearing a big gob of grease!!
  4. videoeic
    videoeic Member
    Apr 17, 2008
    5
    NJ
    Thanks
    Worked!
  5. AtlasRob
    AtlasRob Senior Member
    Feb 8, 2008
    1,983
    owner operator
    West Sussex UK
    Ok
    Ye, but you forgot the pictures :Banghead
