kshansen
- Joined
- Mar 11, 2012
- Messages
- 11,162
- Location
- Central New York, USA
- Occupation
- Retired Mechanic in Stone Quarry
I think I see the problem with that clutch, the throwout bearing fell apart!
Since it's just a throw out bearing do you get a new one and put it back together or replace clutch to while I got it apart
That's a Spicer Angle Spring clutch, the throw-out bearing is part of the pressure plate assembly. Sure if you are trying to save a buck one could probably buy just the throw-out bearing and not take the clutch out but don't think I would try that unless I had an old one sitting there and was going to trade off the truck next week.I've rarely taken a transmission off where I haven't just gone ahead and done the clutch, unless I was just there a year ago and replaced it. You can pull the clutch and inspect it for wear, and look at the flywheel.
If you're fixing it to sell it, just do the throwout bearing, if you're keeping it for 5 years and need it, I'd spend the $ and do the clutch while I was there.
Yes sir the balls were all laying in the bottom of bearing case.
Usually when I do a clutch adjustment I find a reference point and mark the balancer with a paint pen using a "CL" mark. Easier to just line it up with the appropriate turning tool and be done with it with out the 2 man "bump it" method. But then I see the same trucks over and over.I thank 6 cylinder engines normally stop at one of three places. If the engine has not been turned install the pressure plate with the adjuster at the bottom. Then it should be easy to find for adjusting in the future. Mark a reference spot on the flywheel before removing it. That makes for quick and easy installation.
Ok not meaning to hijack but, since you brought up the clutch brake Truck Stop, I had to cut out my factory one in a 2005 KW900. It was wore out. I replaced it with the hinged style, TRP I think. About once a year it breaks the little ears off the inside. Is the babcock better in that way. I have not tried that brand before.
Ya I know don't push the pedal down all the way while you are still rolling.
Would you not use the factory one since he has the trans out?
still learn'n: That is a neat looking set up but I question some things. I prefer a larger fixture under the transmission that allows adjustment of tilt front to back and side to side. Also being able to move side to side can be beneficial at times. Maybe you have some of that and I just can't see it in the pictures. I am sure you will work it out. Keep us posted.
