Final drive Synthetic lubricant
Discussion in 'Excavators' started by jack345, Mar 3, 2012.
  1. jack345
    jack345 Well-Known Member
    Dec 2, 2010
    134
    Montana
    Considering the cost of final drives would it be wise to use Mobil one, Amsoil or other synthetic gear oil in final drives? Thanks.
  2. 06Pete
    06Pete Well-Known Member
    Jan 30, 2012
    169
    MD
    I just replaced it in my 315 finals and when I went looking for 50wt like it called for I could only find it in semi synthetic or Amsoil the Amsoil was $10 more but I think well worth the value. It was $150 for 5 gal bucket but consitering it should last 2-3 times as long as conventional oil I think it is worth it. I also use it in alot of engines and so far it has worked out well as with sampeling oil I have extended drain intervals to as mush as 4 times and then the oil was still good But I changed it anyways. So I do think if you are going to keep a machine for a long time it is worth it oil is cheep parts and mechanics are expensive.
  3. pp13bnos
    pp13bnos Senior Member
    Sep 30, 2011
    300
    Asst. Manager RCCDinc
    Gervais Oregon
    You guys think about using it in a dozer? Hmmm...
  4. Nige
    Nige Senior Member
    8,384
    Dozer or excavators - makes no difference. Final drives in operation generate large amounts of particles, especially if you track your machine long distances. The particles can be metal from wear or dirt getting in via the seals. Either way they don't do the system any good and should not be left in there any longer than is humanly possible.
    The final drive has no filter so IMO it's better to change the oil more frequently than less. A regular TO-4 SAE50 is fine as regards lubricating properties, so I would go for a straight mineral oil and change it more often to get the particles out of the system. I can't believe it's hard to get a straight mineral SAE50 oil.
    We actually cut the oil drain interval in our excavators in half when our operation changed from moving machines from one end of the job site to the other using a lowboy to walking them, just because oil condition deteriorated so much more rapidly when they were walked long distances. If we go back to using lowboys again we'll go back to the original oil drain interval.
  5. Canadian_digger
    Canadian_digger Senior Member
    Nov 1, 2007
    554
    Ontario
  6. jack345
    Dec 2, 2010
    134
    Montana
    Great info . Thanks
  7. Nige
    Nige Senior Member
    8,384
    I would also point out that in colder ambient temperatures a TO-4 SAE30 oil might be recommended instead of a 50 in excavator final drives. Dozers all generally use 50. Have to check the manufacturer's recommendations before buying.
  8. buckfever
    buckfever Senior Member
    Aug 13, 2010
    797
    southwest pa
    We cut all our drian intervals in half no matter what. Seem to work for us, have machines with 15,000 hours and more with all the original engine parts.
  9. buckfever
    Aug 13, 2010
    797
    southwest pa
    But it is a deere so that may have something to do with it:D
  10. rare ss
    rare ss Senior Member
    Apr 1, 2011
    460
    Western Australia
    CAT's Komatsu, Hitachi we would sample at 500Hr and change at 1000hr, or earlier it required, the only machines we had issues with were sumitomo diggers which require a higher spec oil, Castrol GOJ90 in lew of 80W-90
    mind you most machines would get walked alot, in quarry jobs the main digger would get 2000hrs from the final drives easily
  11. Nige
    Nige Senior Member
    8,384
    I would go further and say that even if you cut change intervals by half or by any other percentage that works for you, it's not necessary to throw the oil away. If you get hold of a filter cart with an on-board storage tank it would make sense to drain the oil and then filter it. At that point it would be fit to go again.
  12. rare ss
    Apr 1, 2011
    460
    Western Australia
    afew of the older guys I've worked with used to run used trans oil in grader tandems, it was just the done thing back in the day, drop out the trans oil and replace the tandem oil with the used trans oil
    if you have a good sample program and record keeping is the way to go IMO, magnetic plugs for final drives are a must also..
