Sorry for not replying sooner Zee. This thread must have fallen through the cracks while I was out of the country due to a family bereavement in March.Hi Nige,
I work for a mining company and have few Hitachi excavators like EX 3600, EX 5500-5, EX 5500-6 and Hitachi recommends zinc free hydraulic oil.
I have been using zinc free hydraulic oil since day dot but still see zinc levels in used hydraulic oil upto 30-50 ppm and all excavators are going through varnishing issues in pumps and valves which result in jerky hydraulic operations.
I have checked with some other mining companies here in Australia and they also experience zinc levels in used zinc free hydraulic oil from these excavators. and they are seeing levels of zinc more than 100 ppm.
Please note that the hydraulic filters used here are not usually fleet guard filters which are known for having leaching zinc in the oil at operating temperatures for hitachi hydraulics. Hydac filters are predominantly used in these applications.
Can you please shed some light on where that zinc in oil would be coming from?
Thanks
Zee
Well, My main inside man at Bobcat tells me that the new and "improved" motor oils have had important ingredients removed to comply with the new federal emissions requirements regarding low-ash and so on, MAKING IT NO LONGER SUITABLE for use in hydrostatic systems in Bobcats of any age. Now they use a high grade hydrostatic hydraulic fluid similar to Case Hy-Tran Ultra, or our Chevron 1000 THF. New Saying: "If it ain't broke the Feds will figure out a way to break it" NOW Bio-Diesel 5% Minimum is causing a major pain with tier-4 aftertreatment too!!!
You might be better using an SAE10W TO-4Dresser TD7G is one example of the manual calling for engine oil in the transmission including hydraulic pumps, and gears, and steering clutches & brakes. Then they go one saying it must meet TO1 specs, and be #10. I've never seen an oil meeting all those specs. I'm going with Hy-Tran.
