elevaing grader
JDOFMEMI
SoCal
Quite the contrast in the picture you linked to.
The M series blade sure looks out of place there.
DonBC
Gabriola Island, BC, CAN
Retired mechanical engineer.
That brings back memories of where I grew up in southern Saskatchewan. Kramer Tractor was and still is the major Cat distributor in Saskatchewan. The soil in southern Saskatchewan is particularly suited for constructing rural roads there. When I was a kid our local municipality had a pull type that they original pulled with an old Cat 60 and a pull type grader that they pulled with a second 60. They eventually acquired a D8 dozer to pull the elevating grader and a Cat #12 grader to build our roads. One 60 was retired as a parts machine and the other 60 was still used to pull a small cable scraper.
blademan150
No. Il
Retired Local 150 Operating Engineer
elevating grader
Graderfan1981, These are some pics from a local thresheree and equipment show I went to, the pull type elevating grader is owned by the company I worked for before I retired.....no that's not the grader I ran for them, but I did run blades from 8t 12's right up to 160Ms....... blademan150
