dust suppression water freezing up
kevink
North Texas
Anyone have any tricks or experience with heating water or antifreeze chemicals to add with water for my dust suppression in freezing temprature
Thanks in advance
redneckracin
Western PA
Civil Engineer
Don't shut the pumps off. Drain the lines at the end of the day. You could add heat trace lines and insulate if draining is infeasible.
Bls repair
S E Pa
Equipment operator,mechanic
Could make a salt solution like they use on roads . I would think plastic pipe would be best. May not work if it got stupid cold.
Planedriver
Central Michigan
Farmer
We use urea at the airport for runway deice since it is less corrosive to aluminum. I would think a diluted solution would work for your application.
grandpa
northern minnesota
Straight salt applied directly to the road surface will work too,,, it pulls the moisture from the air... no mixing no fuss, just results.
