crane operator
If its a set back front axle, short nose, where the engine is 1/2 under the firewall and in the dog house, I probably wouldn't try to fix it with it in the truck. I find myself always touching the firewall or rapping on something and dirt and crud from the firewall falls down into the engine. If it was in a big long hood with the engine out and exposed, that's a little different.
I have a big A frame gantry and forklifts etc., so its not too difficult for me to pull a engine. If all you have is a big tree and a come- a long, that would change.
Depending on how much you use the truck, I would consider a used/ junkyard motor. If you need it running, and can pull the motor, you could just have a different motor there and go back together. Used motors are like used trucks, you don't know what you're getting. But I always figure the motor made it to the accident.
I guess one other question, I see you're in california, is it worth spending the $ on a truck that the state isn't going to let you use? Or are you under their mileage restrictions?
