Dozer blades
Discussion in 'Dozers' started by Imaginemw, Jan 1, 2010.
  1. Imaginemw
    Imaginemw Member
    Dec 15, 2009
    23
    Welder/Fabricator, Dozer owner/operator
    Ballico, California
    What are the different types and descriptions of dozer blades. What blades are suited for what types of jobs?
  2. flyboyziel56
    flyboyziel56 Member
    Jan 2, 2010
    12
    florida
    I guess the question comes to mind is what are you searching for?. There several types of blades for different applications!. You have earth moving, Roads, Coal, Mining, the list goes on. There are several manufactures of blades, Depending on the type of work. Hope this helps some what?. Allan
  3. Imaginemw
    Imaginemw Member
    Dec 15, 2009
    23
    Ballico, California
    Sorry, I guess my question was pretty wide open. I'm really trying to fiqure out what my 1987 Cat D4B has. For some reson I am unable to upload a picture. However, my blade is straight across the top and bottom, then flares out about 6" at the sides. Creating somewhat of a "U" shape. What would this blade be best suited for?
  4. captcws
    captcws Member
    Dec 28, 2009
    18
    semi retired
    Al, Tn, Ga
    Most likely because of the type tractor it is on would be general grading, don't think I have ever seen a true 'U' blade, which is a high production type blade for larger tractors( D8, D9,D10), on a D4
  5. special tool
    special tool Senior Member
    Jun 15, 2008
    878
    Bethel, Ct.
    Sound like a "semi-u blade", from what you describe.
  6. flyboyziel56
    flyboyziel56 Member
    Jan 2, 2010
    12
    florida
    Generally speaking a D4 was used for finishing or slope work. It's a machine weather a " High drive " or " Low Drive " Is indeed a general duty machine. Most of these blade configuration were either straight blade or " 3 " way blades, meaning it has a valve on the front control that allows you to tilt, angle, and lift. Hope this helps!. Allan
  7. John C.
    John C. Senior Member
    Jun 12, 2007
    3,574
    Equipment Mechanic
    D4B machines either had an angle blade or a semi universal blade for the most part. I have seen a machine with a custom built U blade and a winch that was used in the logging industry for something. It was too small to cut road and too heavy in the front to drag logs.
    Later small machines use a PAT blade configuration. PAT stands for power angle/tilt. Some people refer to these as six way blades.
  8. Imaginemw
    Imaginemw Member
    Dec 15, 2009
    23
    Ballico, California
    Thanks, I gather it's a six way with a straight blade. I've been very impressed by how well it does the finish grading. Very easy to control and create smooth surfaces.
  9. willie59
    willie59 Super Moderator
    Dec 21, 2008
    11,430
    Service Manager
    Knoxville TN
    The way I read his question is what are the different types of blades, and what is each used for. There are 3 basic blade designs; Straight, semi-u, and U blade. The straight blade is just that, a straight cutter bar blade with no wings on the end. Ideal for finish work. Straight blades will typically be PAT as John C stated, allowing operator to change blade positions to do finish work. With no wings, spoils will roll out ends leaving windrows. The semi-u is straight until it nears the ends, then has small wings that turn forward. Used for some finish work but more for general dozer grading. The wings of the semi-u allow more material to be carried without spilling out ends. The U-blade is typically used in high capacity moving of material, like a coal pile. The large wings of the U-blade allows the operator to fill a big pile of material and fill the blade, then push it a good distance, carrying the material to a desired drop point.
  10. td25c
    td25c Senior Member
    Feb 15, 2009
    3,441
    indiana
    Well put ATCOEQUIP,dont forget cushon blades for loading scrapers,rome plow for clearing trees,& root rake blade for cleaning up ground & piling brush.
  11. willie59
    Dec 21, 2008
    11,430
    Service Manager
    Knoxville TN
    Yep, there are other blades 25c, I was just describing the basic blade designs. I've also seen a blade hinged in the middle to make a V, used by forestry service cutting fire lines. OCR may have seen one of these.
  12. Balzomedic
    Balzomedic Well-Known Member
    Aug 30, 2008
    91
    Welder
    Northeast Oklahoma
    Are blades ever manufactured with a tree pusher on them, or is that strictly an aftermarket modification?
  13. JimInOz
    JimInOz Senior Member
    Apr 15, 2008
    405
    Spare Parts Supplier
    Victoria, Australia
    Here's some pages from my Komatsu catalogue from the 80s.
  14. willd8r
    willd8r Well-Known Member
    Dec 11, 2008
    129
    dozer operator Cat D11R
    Hi Anyone heard of or better got any photos of the D8R & D9R blade with the rippers in them They where made by Cat or ever made the blades for them I worked with a guy who said for roading rock work stumping etc very good
  15. JimInOz
    Apr 15, 2008
    405
    Victoria, Australia
    Will D8R,
    Here's an early Cat D7 with "ripper blade".
    Also an IH doing good work clearing stumps.
  16. Balzomedic
    Aug 30, 2008
    91
    Welder
    Northeast Oklahoma
    That's a pretty mean looking blade there! I could sure use that pulling all the stumps out that I do.
  17. Bacho
    Bacho New Member
    Feb 7, 2010
    1
    Greenville SC
    I cant start a new thread so this thread seems the most appropriate for my question.
    My Grandfather recently purchased a D3C, and bought a root rake blade for it last week. My Father and I tried to install it yesterday, it appeared that we had to unbolt the ball assembly from the dozer and bolt it around the new blade and them put the whole assembly back on the dozer. Trying to do this we were only able to get the whole assembly to slide almost 2" out and it seemed to hit a stopping point. Are we going about this the wrong way? Is there and tricks to this?
