Nice looking W-900 pauly17 !
As JPV noted if you plan on keeping the truck and the frame is a concern then by all means go ahead & double frame it while your swapping out the rears .
Myself don't see any problem with running the new liners up to the cab with that wheelbase of tractor .
It's not like your trying to do a tri or quad axil dump truck conversion on it .
When we did our W-900 we framed one side at a time sliding the new frame section in from the rear & used a magnetic drill press to poke out the holes in the liner .
Cross members had slotted holes in them to allow adjustment for thickness of new inner liner .
As member Truck Shop stated throw away old bolts & hardware & go back with new .
Another note.... Make sure the fab shop allows a little tolerance between the flange on the new channel . If anything make it a little short between flanges so the new liner will easily slide in the existing frame .
