chansey
I have a 1989 1500Z Trojan Loader that that has a Dana/Spicer (Clark-Hurth) 3 Speed Powershift transmission and the transmission is being overfilled with hydraulic fluid. The overfill is about 4" above the full mark on the dip stick and then hydraulic fluid starts running out the bottom of the flywheel housing. Hydraulics work fine until the hydraulic tank runs low.
I have two inspection holes on the FH cover and there is no fluid around the outside of the torque converter or other wet areas that I can see. Fluid is not flowing as though the fluid is under pressure but leaking through a seal leak. I've looked at the flow schematic and the only connection between the transmission and the hydraulic system is that the transmission drives the main hydraulic pump.
I rebuilt the main hydraulic pump and replaced the front bearing and seal. This had been a major source of a leak into the transmission, so much so that the breather and fill tube would over flow. After re-installation, the leak stopped for a few days and then started up again. I was able to back off the bolts on the pump and verify that the pump was no longer leaking.
Looking for input from someone who has experience with these transmissions or can identify the source of the hydraulic fluid entering the transmission. Been chasing this issue for a very long time ..... help me put an end to my misery.
