Mr Science I Ain't...
Amazing what you can do on a rain day...
Not a strut, it's (1) a hydraulic cylinder, and (2) a nitrogen filled accumulator, a gas pressurized tube with a piston, more like a huge gas shock. 1200 or 1400 psi, I think. Check out the link for the parts involved, it's pretty complex. I couldn't find the patent application for the accumulator assembly, and it's not shown in those tech diagrams. Although the scraper pics show it.
Lots of valves, a pump that runs off the transmission, and the load sensing device is a rod, attached to a sensing valve on one end, and a little leaf spring on the other, that senses the load on the hitch and the height also, and adjusts the pressure the pump supplies to the hitch cylinder accordingly.
Not bad for a guy who just runs the things....
Even the seats in some of these things run off the transmission, they have their own little hydraulic system, and a little nitrogen cylinder under the seat that cushions the bumps. I think the newer scrapers did away with this, and just use an air ride.
If you,ve got a ton of time on your hands, check out some of the stuff Cat has patents for over the years...
http://www.google.com/patents?as_dr...=caterpillar+tractor+company&lr=&sa=N&start=0
Lots of pages here...
alan627b
