Differences between scrapers...
BrianHay
Nanaimo B.C
LOL check that move out eh lol even got a pic up quik (helps that they all cam phone pics so don't need to resize)....think I'm finaly getting it all figured. Just gotta get those smileys figured out better now. some of those placed right crack me right up
pushcat
USA
I have never worked with the pull type scrapers so I don't know much about them. They seem to be getting more popular though. Tractors are for sure way smother ride then a scraper. What was the bad luck you had with self propelled? What kind were you using?
It was several years ago and I was so unimpressed I can't remember exactly, I think it was a 613? Does that sound right? It got stuck on a turd, always had to push it around, even even going up a small greasy hill empty where the Steigers just walked around it. Most of our jobs are smaller so we don't need the huge scrapers, but we can still move 50,000 yds fairly easily with 2 or 3 tractors.
alan627b
Omaha Nebraska
Heavy Equipment Operator
On twin engine scrapers, the transmissions are synchronised electrically, and the rear throttle runs off pressurised air. Unless Cat got silly and put a drive by wire throttle on the G series.... Always fun in the winter, if ya get one no one has drained the air tanks on all summer....
The 613 has a cab designed for a midget.....
As far as articulation, you can get one side of the tractor to pitch up a pretty impressive amount..scares new guys sometimes... but as long as the scraper stays level, you are generally all right. The most important thing to remember about making a scraper cut is that the attitude/level of the rear wheels determines how the cutting edge cuts, You can put one wheel in a hole to key in to a slope, or start a ditch, for instance. Learning the tricks is what makes you a useful operator.
Believe me, I learned some of them by mistake....see picture at left...LOL!
alan627b
BrianHay
Nanaimo B.C
Scrapers will sure do some amazing things eh. The only thing that realy limits them is the imagination of the operator. I love working on slopes with them. I'm an adrenalin junky. There is almost no slope you can't tackle if you aprouch it at proper angles. Especially with a Terex TS 14. Of the machines I have operated they are the most stable. Done right you can trim a 1.5:1 slope. You have the tractor running almost but not quite parallel and the scraper running diagnal. Feather the back motor just enough so its keeping you from sliding down but keeps sliding you sideways without pushing you up. And the front just enough to keep pulling forward. The tractor will go right up onto the bumpstops once in a while but you can't roll because the scraper is hanging onto you. Give the wheel a good tug down and it comes back onto all four wheels. What a rush. Next to never get to do that kind of stuff anymore though. With the safety regs nowadays people start to get nervous even when klimb up on a 2.5:1.
surfer-joe
Arizona
OK, ya talked me into it and I've had my nap already. I started out on a Ford 8N tractor with a scoop in the back mounted to the 3-point hitch. Some folks called them a Fresno. Next was a Euclid S7, neat little machine, noisy and not too fast. Detroit 471 engine, Allison auto, hard hitch and a bouncy ride sometimes. Graduated to Letourneau D-Pull. About the same size as the S7, same engine, standard 5-speed tranny, and of course, electric steering and cable controls for the bowl. My brother and I owned four of these around 1967. Pushed them with the Cat D8 2U tractors. Very bouncy! Had a hard hitch.
After that, MRS (Mississippi Road Service) 110's and 200's. The 110 was a four-wheel drive tractor pulling a 14 CY hydraulic scraper. The scraper could be remounted on a fifth wheel axle assembly and pulled by a Cat D7 or 8, or in our case, a TD20B International dozer. The 110 tractor could steer the front axle, the rear axle, or both together for crab steering. Never saw any advantage to this arrangement for crab steering, but it scared hell out of the locals as we were highballing it down the highway. Anyway, This tractor had the Detroit 6V53 and it was a real screamer at about 195 HP. 6-speed Allison tranny and a hard hitch. These units would rock you to sleep going down the road, but were so crammed with high-tech stuff that they weren't very dependable. The scraper bowls made excellent gun pits in a firefight.
The 200 was a monster we thought, and I actually only ever ran one in training in Rhode Island for a couple of days. The tractor had a 450 HP Cummins, a thirteen-speed Road Ranger with a two-speed locking-differential, air brakes -- which could be applied by hand to the right or left drive wheels, and a drawbar that was rigged with a weight transfer device. The scrapers we had were hydraulic, but I've seen pictures of these creatures with a PTO rigged for cable. The weight device was used as you began getting a larger load in the bowl. With the big engine, you would lose traction easily, so you started applying pressure from the scraper hitch to the tractor drawbar. The more loaded the bowl became, the more weight you could transfer to the hitch. You could get real busy with these critters as there were more levers and things to use for loading, turning, traction, and unloading than one man could handle by himself, not to mention steering and shifting gears.
I used a 200 tractor with a standard 5th wheel dolly to pull a Rogers 50 ton loboy all over Northern I-Corp in Vietnam. If we could get it on the trailer, I could pull it. Steering was slow to respond, and my favorite tractor had a two-speed differential that I had to stop, crawl under, and shift by hand as the control was busted. We had one other one that was faster by about 5 MPH, the engine was set to a higher RPM, but my old girl was a real hog at pulling and would pass the other fella going uphill easily.
MRS built very large scrapers back when Cat was just thinking about getting into the business. I believe the largest was a double barrel unit running about 50-60 yards heaped. Never saw one in the flesh, but maybe some of the boys here have from down along the big muddy. That's where they made em.
The Army boys, and even the Vietnamese engineers, had the Cat 630M scraper. It looked like the 110 MRS, but we Seabees all drooled over them and wondered why we didn't have any. I never ran one. MRS made a smaller unit that the mud Marines used. It was about a 8 yard machine and used a 471 Detroit for power with an Allison tranny. By the way, all the machines I have described so far have been open or no cab machines, maybe just an umbrella and a windscreen. No seatbelts. No heaters.
I used a Cat DW20 for a few days in Rhode Island, but the Bees were phasing them out by then and I never ran another. Did use a DW21 some in Colorado, didn't like either one much.
There were a host of pull scraper manufacturers way back, you still see them in parks and scrap yards or along side the highway rusting away. They were all cable, and if you have ever had to pull cable through all the sheaves on the dern things, you will understand why they fell out of favor pretty quick when the hydraulics became available. The trick was to not let the cable break completely apart. If you were careful and took it easy, you could spool more cable off the reel and replace the damaged section fairly easily. If it busted in two, you were up for a dirty afternoon. You may notice some Cat cable scrapers with a wooden spool of cable parked up on the right front of the scraper draft-tube. That's what it was there for.
I ran TS14's in Texas south of San Antonio for HB Zachry. They were a fun little machine and would go anywhere. I still like em. These had the 471's front and rear with air-shifted Allison's. The thottle to the rear was air. Hard hitches and they flat would launch your butt in the sky on a rough haul. We pushed them with a single D9G pushcat when the operator was paying attention. The muck in the riverbed there was a combination of gravel, sand, and clay. The clay sometimes would roll into the bowl like a jellyroll, and it just curled up untill that 9 couldn't stuff another ounce inside the apron. Trouble came when we tried to eject the stuff. It was so heavy the ejector couldn't lift up.
OK, some explanation here. S7's, S14's and TS14's, S and TS24's, and all 32's all used an ejector that was a combination of ejector and bowl floor. It was hinged right behind the moldboard and it lifted up and forward to dump the load. Cats and others use a solid floor with a push type ejector on rollers that simply moved straight forward. Some Eucs used two hydraulic cylinders, one on each side, to lift the apron whereas Cat used a single cylinder with a dog bone and a banana link on top of the gooseneck to lift the apron. Some other makers used a similar setup, only with a cable instead of the dog bone link. The TS14's used this last style.
So, where was I, oh yeah! Anyway, dumping the 14's with a big roll of clay was tough. If it wouldn't dump, we would back up a bit, then charge forward with the apron wide open. There was a trick to getting the aprons to flip up and backwards out of the way completely that we learned to use, but the master mechanic didn't like us doing it. Well we'd charge forward, apron up, then hit the ejector for up and the trans shifter for reverse, all at the same time with full RPM on the engines and a hairy handed grip on the wheel and the ejector lever. Most of the time that roll of clay would just spool right out and we would make a hard 90 degree turn to the left or right to clear it. The master mechanic didn't like us pulling this trick either. But once in a while, we couldn't get it out and we would have to go over to where a Cat 225 excavator was working and have him dig some out. That was considered a great loss of face for us and we hated like hell to do it.
Shortly after that I went on to Colorado. Denver was doing a boom at the time and there were literally dozens of International 295 elevating Payscrapers all over town working on housing developments and highways. This is the first place I ever saw pushcats used behind elevating scrapers. The reason for it was that they were working on benches so high and steep that they couldn't even get up to the bench by themselves let alone load. The Cats eased them up and then stayed behind as the can loaded up. They didn't really push hard so much as just kept the pan moving gently. Most of Interstate 25 from the New Mexico line to Ft. Collins was built by these rigs.
I ran a TS24 for an outfit building housing pads and roads over near Morrison and that was a blast and a half. Euc scrapers were some of the easiest loading scrapers in the world, mostly due to the angle of the moldboards. Cats used a steeper angle and were harder to load, even when being pushed. The Eucs were much faster to dump too. The 24 had no cab and that was a cold winter and a late spring. I bought a pair of Air Force high altitude flight pants at Jax in Ft. Collins, and with a big ski parka and ski mitts, along with some Antarctic inflatable boots, managed to make it Ok without freezing too bad.
Paddle-wheel, or elevating scrapers, are an interesting device and the smaller units are kinda fun to run. 613's are a hard hitch machine and prone to bounce real bad. Early units used the 3208 boat anchor engine, and disc brakes on all four wheels. The brakes worked well, but in wet clay type soil, the rear wheels would just drag all over and the front wheel would spin like crazy. We learned to just go home when it rained. The calipers on a disc brake are designed to drag slightly, and Cat never figured out how to make them drag less so you could move the machine in mud or wet clay. It was an interesting year and I learned to extricate my 613 from almost every conceivable situation. I would teach these methods later on to 613 operators in several places.
After college, I wound up in Florida working for an AC dealer with lots of 260 and 460 open bowl and 261 elevating scrapers working all over the state. Most of those working in the Ft. Lauderdale area were 261's, and while there were a nice machine to run, they were a real b*****d to work on. These were all hard hitch machines and had a lot of transmission trouble. Believe it or not, you had to remove the engine and tranny as a unit. What a drag. The steel used in the elevator paddles on these machines far outlasted those used on the Johnson scrapers being sold by Cat at the time. Some of the 460's had the GM engines, and some were using the newer Buda/Allis Chalmers.
Well, I'm up to the limit tonight, got to go.
BrianHay
Nanaimo B.C
Thanks for the history lesson Joe. that was a really interesting read. Have you ever seen a ripper on the back of a scraper? I ran an old TS14 (67) for a while that had one. It worked great. Never seen another since. I thought it was a great idea and often wondered why they never cought on.
Countryboy
Georgia
Load Out Tech. / Heavy Equipment Operator / Locomo
Excellent reading there Joe. Great stuff. :drinkup
I got to thinking about it and our small water truck is a 613B enclosed cab. I always thought it was a water truck by model number but you say there are 613 scrapers?
I drove it a couple times when I didn't have anything to do but I didn't like it to swuft. Not the machine itself but the problems it had. Main problem is it steers to the left perfectly but if you want to go right, you have to wait about a minute for it to go all the way. :rolleyes:
Canton, Ok
miner & blaster
657g
What does everyone think of the new 57's? We have 2 new ones, they are nice srapers to run now that they have the single stick setup, but they seam to be underpowered. They went to I believe a acert 19 in front and an acert 16 in the rear. They just dont have the power that the older scrapers we had. We are having lots of problems with the wiring between the front and the rear of the scraper. The rear quits pulling and sets of all the buzzers of and it wount move. They big wheels at cat are comong out to try to figure out what is going on. One of the cat mechanics here Said that the new 657G have 6 computers on them now. The last 657's we had only had 4 of them.
surfer-joe
Arizona
Saw pictures of rippers and winches mounted on the back of scrapers and other far out configurations, but never came across a live one.
The 613 was the first elevating scraper that Cat made, they used some Johnson and maybe some others (Hancock?) before that for a model they called the 619, but the 613 was their first totally made in house model. The fact that it's still being produced today is proof that it was and is a viable design that works well for a lot of contractors.
613's have been made into many different things including water wagons. Mega in New Mexico started out using contractors own used machines, then bought a few used ones themselves and rebuilt them, now buys new ones from Cat to use. But they will still use yours as well.
I remember some outfit in Colorado that built a lot of freeway with the 619's. The crew would actually set up camp near some shade trees and live on the job for weeks or months in campers and trailers, even tents. They helped build one of the last open stretches of Interstate 70 west of Parachute right at the entrance to DeBeque Canyon. They had maybe 8 or 9 of these machines and were always working on a couple of them under a Cottonwood tree.
BrianHay
Nanaimo B.C
Hi Gary I haven't had the opportunity yet to run a 57, would realy like though. I love the big iron. But a company I used to work for bought 2 627G's. I the begening they had all kinds of problems with the electrical to. One had to have the joystick repalced twice in only a couple months. And once in a while when you went to put it in gear again after stopping for lunch the front would try and go forward and the back would go into reverse. Took a while to work the bugs out but once they did they were great machines. I loved them. All kinds of power, they are like big go carts. Couple years later they got 2 637G's and they were great no real problems with them. But they didn't seem to have anymore power then our series II E's. In fact the E's seemed to have more bottom end power. All in all I love the new G series. What a step up for the operator eh. The cab is like an office. Cat didn't leave much out when they buit them. Even gave us a swivel seat and 2 buttons on the floor for the dif lock to make it easyer to run with your left foot.
BrianHay
Nanaimo B.C
Camp set up on the job is still quite common here Joe. For a solid 10 years camp was purty much my home (was married and had a house but was never there, camp felt more like home with my house just being a place I visited once in a while). Usually Atco trailers connected together. The biggest camp I stayed in that was on the job was when I was twinning part of hiway 43 near Valleyview. We had over 130 people in camp at peak and it was set up right beside the hiway. When I met my second wife and she started traveling/working with me 5 years ago I bought a holiday trailer for us. We rented a house for a short time but it was pointless because it just turned out to be an expensive place to store our stuff. We were never there so gave it up and upgraded to a nice fifth wheel. Usually find a nice campground nearby but still camp on the job once in a while...sorry guys a little off topic there.
JBL
Missouri
Didn't see anyone say anthing about kicking out the cushion hitch when loading. You can sure did a hole quick if you don't kick that thing out when push/pulling. :D
Countryboy
Georgia
Welcome to HEF Gary M. Martin! :drinkup
richardcatdaddy
Versailles,Ky
heavy equipment hauler,local
subject
Well I have never been hooked to another scraper,only pushed .We have one twin,or double barrell as we call em,an older Terex.Our 613 is a self loader,paddlewheeler like the old steamboat paddle wheelers.We have 621s,621b models a 623 self loader not currently operating due some problems.But anyone of em will beat the operator silly if the pusher hits too hard or dont know what he is doing.:Banghead
europe
639d
Can anyone remember the 639D twin engine elevating scraper Cat produced in the early eighties?
It was not in production for long i dont think.
They had one in Malaga at Cats demonstration ground but never saw one anywhere else.
surfer-joe
Arizona
I remember the 639's, but not very well because there were never many of them produced. Clark produced a double-barrel paddle-wheel and it was a real rip snorter. The only one I ever saw had a Detroit 12V71 fore and aft and it really hauled the mail. I actually have a Swiss plastic model of that machine and one of these days when I can't do anything else I'm going to put er together. It's a neat model. Trouble with the Cat's was that they couldn't run the paddles fast enough to keep up with ground speed. I've never run a Cat auger-scraper, but they are mostly set up on double-barrels and seem to do pretty good.
alan627b
Omaha Nebraska
I got to run a brand new 621G auger scraper in Arizona 2 years ago. Not a bad machine at all, loaded pretty well as long as the ground wasn't too hard. I don't think the auger has enough power to load heavy clay like I am used to in Nebraska. A 627G might have been better.
In looser soils, It loaded as well as the 627B's I am used to, and in about the same time.
Michigan used to make a small paddlewheel, 110- something or other. It had about the same capacity as a 613 or an S11, but had a 110 HP4-71 in both ends. I talked to a guy who had one, he said it would load itself in it's own length! Probably a great finish machine.
John Deere 3 axle 760's were supposed to be excellent fnish machines as well.
Surfer Joe, got any stories comparing whgat the 3 axle scrapers were like compared to a cushion hitch overhung style> I'd kill to run a 666 for a while.....
Keep it going!
alan627b
Countryboy
Georgia
Surfer Joe, got any stories comparing what the 3 axle scrapers were like compared to a cushion hitch overhung style.
Never seen one of them :confused: . Anybody got pictures?
surfer-joe
Arizona
So you want to see some scrapers huh?
Check the ones at this address out!!..
http://www.gordyflemingequipment.com/scrapers.htm
The last picture is a 760 Deere.
Surprisingly enough, I only ever ran one of these. I was home on leave and my brother thought he might want to buy one and knew a guy had one to sell close by. Nothing for it but we go over to the guys house and do a walk a round. It looks OK, and brother wants to buy, but I say wait, we better run the bejesus out of it first, make sure it's OK.
I, being just home from Vietnam, was fit as a bow fiddle and well used to really putting the pedal to the metal. So I jump on this little scraper and just wring it's neck out.
After about 15 or 20 minutes the engine is overheating and coolant is boiling out of the rad overflow cap. The tranny is clanking every time it shifts and the gearbox for the elevator is smoking.
I shut her down and saunter over to my brother and say, "I don't think we want this one." Boy was that guy mad! I guess he thought he had a sucker hooked.
I've seen a lot of these machines around. They used a Hancock scraper with what used to be a 5010 tractor, the earliest ones actually used a big two cylinder engine I think, then was changed to the newer 6 cylinder in-line.
You might notice that this little critter doesn't have a cushion hitch. It didn't have much of a seat cushion either, That was one hard ride. Very bouncy!
The elevators were powered off the tractor PTO with that long driveshaft you can see sticking up over the top of the gooseneck. In hard digging you could stall the tractor with the elevator. That driveshaft was also susceptible to bending easily. But it was a very powerful machine for it's size.
The picture up from the Deere is a D-Pull or model D LeTourneau, not a Wabco. The tires actually look better than most of the ones My brother and I owned. The old girl doesn't look in all that bad of shape. You notice that the covers are off or missing for the breaker and relay boxes on the gooseneck. A little sanding and filing on those would probably make it run almost as good as new, which is say, not real good. We left the covers off our boxes too, so we could take a broom-stick and whack the appropriate switch when it didn't work when it was supposed to. The steering switches were usually the ones that quit. Scary when going down the road in 5th gear and the damn thing wouldn't turn.
This machine had the dependable ole 471 GM diesel, or Jimmy. They weren't called a Detroit just yet. Yeah, geez, the ole thing still has both headlight bulbs, someone took good care of this one. They were otherwise noted as the kings of bounce!
There is a picture of a nice 444 International double-barrel elevator scraper. Rare! Note that hard hitch.
Some good pictures of other scrapers too. That guy has quite a collection.
Deas and squizzy, that white stuff is snow, not Australian gypsum.
Here is another good site for technical information on the 760:
http://johnnypopper.com/weirddeere/NG/The_JD760.html
Enjoy!
