DirtyHoe
My local CAT store has Cat Ultra 5 Moly Part #183-3424 and Cat Extreme Application Grease #452-6001. They both have 5% moly and a Calcium Sulfonate Thickener. So are they the same thing with a different label? Confusing to a novice.
Also, I want to use either one on my Case 580C backhoe. Besides pins and bushings can this grease be used on the rear grease zirks that lube the rear axle bearings? What about the front hub bearings and the king pin needle bearings? I've read that a high percentage of moly should not be used on high speed ball bearings, but these bearings are not high speed.
Thanks,
Steve
Thanks,
Steve
