Deutz Diesel Engine- 6 Cylinder ??
Discussion in 'General Industry Questions' started by Speedpup, Jun 30, 2010.
  1. Speedpup
    Speedpup Senior Member
    Jul 7, 2007
    1,214
    President and all else that needs done!
    New York
    I was looking at a machine with a Deutz Diesel engine that is about 80 hp and a 1986. Are parts available if I need them? How are these engines in general? It is in a telehandler / Lull. Thanks,
  2. joispoi
    joispoi Senior Member
    Mar 1, 2008
    1,274
    The Northeast
    They certainly have a cult following. They're good motors. The salesmen used to pontificate on why air cooled motors were superior to liquid cooled motors with the related corrosion and such. The horror stories they'd spin about water pumps, sludge and frost. :eek: Deutz has now moved on to building liquid cooled diesels. I wonder if the salesmen still use the same salespitch? :tong
    Here's a link to some parts suppliers. Maybe you'd want to give them a call to see if they know what they're doing or if they're just a name on a list:
    http://www.deutzamericas.com/distributors/dynamicpagemaker.cfm?sc=ny&co=us
  3. tonka
    tonka Senior Member
    Jan 14, 2008
    1,555
    Equipment Operator
    Longview WA
    I liked it in my 830 sennebogen, it gave me no problems what so ever. We had trouble when they switched over to cunmmins motors in the 835's....
  4. Speedpup
    Jul 7, 2007
    1,214
    New York
    Thanks!:drinkup
  5. cat980
    cat980 COPPA
    Nov 13, 2009
    114
    heavy equipment operator
    new jersey
    great engines my cousin has one in his stump grinder and i just got a 3 cylinder one for parts
  6. stock
    stock Senior Member
    Aug 4, 2008
    2,018
    We have moved on and now were lost....
    Eire
    They are reliable if minded,the cooling belt is a very weak point and needs to be monitored closely.They can develop hot spots if the fins are allowed to clog up with debris.If you hear a cracking sound it is usually a head gasket and need to be repaired immediately or the head,liner and piston track then requiring replacement, which is a proper PITA.That said they are reliable as any other six slapper
  7. Speedpup
    Jul 7, 2007
    1,214
    New York
    cool Stock thanks any idea what model they used that is about 80 hp in 1986? Do they have two belts on the fan?
  8. willie59
    willie59 Super Moderator
    Dec 21, 2008
    11,486
    Service Manager
    Knoxville TN
  9. John C.
    John C. Senior Member
    Jun 12, 2007
    3,676
    Equipment Mechanic
    They are a single use engine and so expensive to rebuild it is not worth the effort unless you can do it yourself. They last a long time but their cost of operation comes out close to the same as a liquid cooled unit.
    Stock hit the major points spot on. Air flow is the biggest problem I have run into on them. Once they get overheated they start leaking oil and then you can never keep them clean.
    Pull the sheet metal off the outsides and look closely at the joints. The heads and bases of the cylinders are real important. If they appear to be leaking you will have to give serious consideration as to how much you want or need that machine.
    Good Luck!
  10. barklee
    barklee Senior Member
    Aug 5, 2009
    890
    ohio
    Great engines, we have them in nearly every lift we have FL-1011 models. Stock is correct on the major issues. They have a few annoying problems though, they use a rubber fuel rail with plastic fittings. They leak leak leak! Keep a piece of it on the machine at all times! Check the belts often and keep the fins on the cooler clean, other than that expect good luck!!
  11. tctractors
    tctractors Senior Member
    Oct 9, 2007
    1,956
    Worc U.K.
    In the U.K the Air Cooled Engines are rated on the top of the Hill, the parts are no problem to get for even very old long serving engines, the blower fan on most units has an Engine shutdown in case of belt troubles, the parts are very reasonable to Buy even from Deutz, to recondition the engine would be less costly than most Engines plus the air cooled units are still being built,as already stated Deutz also build Water cooled engines in Vee and inline spec', the big benefit with an Air cooled engine is it only uses 1 3rd of the fan moved air that a water cooled engine needs, plus you have no water pump, radiator hoses plus coolant, most Water cooled engines also often need Vee Belts to drive larger fans, so the blower belt thing is not an issue, the Build quality of the Air Cooled Deutz is about as good as it gets, I service and maintain Vee 10 and Vee12 units on Drill Rigs that are Hammered every Day with just normal servicing to keep things Sweet.
    tctractors
  12. Speedpup
    Jul 7, 2007
    1,214
    New York
  13. Cat Wrench
    Cat Wrench Well-Known Member
    Mar 28, 2010
    121
    Missouri
    MEMO-Omega for deutz parts; http://memo-omega.com/
    My experience with deutz is they are decent engines, but more expensive than most to work on.
  14. MrKomatsu
    MrKomatsu Senior Member
    Jun 12, 2009
    430
    Houston Tx.
    they are the most precise engine out there...in 1980 i was blessed to go to Deutz factory in Germany and i was impressed...each engine was hand made and assemble one at a time....912 and the 913 's are very strong...
  15. Kgmz
    Kgmz Senior Member
    Mar 21, 2007
    308
    General Contractor
    Portland, OR & Eatonville, WA
    Have also dealt with these guys and they are reasonable for prices compared to most others. I bought a rebuilt F2L-511 from them for our Grove AMZ-66 man lift.
  16. Speedpup
    Jul 7, 2007
    1,214
    New York
    Well I lost the bid for 100 bucks at 6100 I waited till the last 3 seconds :(
    Thanks all for the info
