Just swap an injector from 1 hole to the other, to find out if its an injector problem..
OR just get a rebuilt set of injectors.. they're pretty inexpensive..
Just take the valve cover off & inspect the fuel rack.. that what controls the injectors.. maybe you'll get lucky & find one of the adjustments came loose.. & check the valve settings while your there..
Its NOT uncommon for a Detroit injector tip to blow off, normally water is the culprit, so check your fuel & filters..
IF you have to remove the fuel control rack & have NEVER set a rack before.. GET HELP.. OR take it off as an assembly & don't mess w/ the adjustments..
Personally, I would get a cheap temp gun & shoot the exhaust to find out which cylinder it is, rather than guessing.. Good luck.
