gary808
Hello everyone,
So we're working on a d9h that had a steering clutch non release issue. What had happened was the outer hub walked loose and the nut and the lock bold ended up in the basket. When the clutch was applied it caused the clutch to smash and jam.
The last owner pulled the outer shaft and fixed and pressed a new hub on. They changed the piston seals but didn't do the swivel seals behind the hub.
When we got to the machine we tested it and found the swive seals were gone. We also checked runout on the inner hub and found 10 thousandths run out on it.
We pressed the hub off and found what looked like the front half of the taper belled.( looked looseand worn)
The hub has been making metal to metal contact where the seals run with the bearing housong.
We did out best to check run out on the shaft itself using a feeler guage against the threads and a dial indicator and got 6 to 7 thousandths run out.
Does anyone know the max permissible run out on the shat?
We're looking into either replacing the hub and bearing housing or changing out the bevel shaft.
