Good deal. We pulled the clutch drums out and got the brakes replaced. I really appreciate your help and knowledge. While I've got you, I need to pick your brain on something. I just drained the transmission oil on this 7. (48A10837)
I've filled it back with 30 gallons of 30wt. I also changed filters. Problem I'm now having is that after pushing for 10-15 minutes, it sounds like the pump is cavitating and movement will eventually stop. I've checked the pickup hose and double clamped both sides, and it's still doing it. Where would you look next to figure out the issue? I cant see any obvious leaks, but I'm wondering if it's sucking air somewhere or if the flow is restricted..
Let me know what you think.
Thanks
Chad
