you should get a written report from CAT on what is wrong and what may have caused the damage to the lining, ill bet the rebuilder blames you in the end..... just for argument sake at this point, what would the cost have been to bring it from the beginning to cat or another reputable mechanic to have the same job done? this way any issues like this would not be your problem, you would have gotten back a good running machine...and what has your cost been so far? time and aggravation and no use of the machine?....sometimes going what we think the cheaper way doesnt work out that way in the end..many have been down this road before...I checked out the warranty on the long block 3306 from Capital Remand and Exchange, they will warranty the engine but,I would have to take the engine out, put it on a pallet and send it to off to Denver where they could do a thorough inspection, all at my expense. They have not answered my last email. I will update!!
....I am hoping it is not too bad!I used some either on it at first startup.....
That engine is out of time. That's why the throttle is not acting right and has no power. Do you hear that detonating sound?
I don't know how long it has run but that can cause the pistons to gall and seize or burn up a piston. Of course, that's going to ruin the rings if the cylinders are galled and that could explain the extreme blowby.
The galling can also be caused by lack of lubrication...and the oil pressure on the gauge doesn't look good.
I'm pulling for you buddy. Wish you were closer where I could lend a hand.
Were it me, first thing I would do is to pull the head and have a look. It's definitely damaged inside.
......They then noticed that the rocker assembly is not the correct one for the 3306 caterpillar engine long block I got from Capital Exchange, I used the rocker assembly from engine that went bad on me, which has a 5/16th hole on one end drilled .Oil was shooting up like a fountain, lubricating the top end but starving the cylinders and pistons from getting oil...
IF CAT fixes it, it has a CAT WARRANTY.. don't get caught up in buying another machine by say-so..& NO WARRANTY..
shlt happens...look at it this way...its only money...yeah it sucks to spend more but thats life, we all have issues like this no matter if its on a house, car , equipment, livestock and so on..its not even close to the end of the world..you have your health and you get up every morning on your own , able to feed yourself and take a dump and not have some bag connected to you..so in the big picture of life, this is just a speed bump for you..me personally would go with whatever CAT recommends to fix and repair the engine with a warranty, also since the machine is there, spend a few more bucks and let them give the machine a good once through to find and fix any other issues, or at least have them tell you what else is wrong and what really needs to be fixed for overall health of the machine..then with all your documentation goto the engine re builder and demand reimbursement for the short block and threaten legal action to cover the rest of the costs that the bad short block caused, such as having to now have a CAT dealer fix the issues..you may or may not get any satisfaction from them, then its your choice to follow through with court ..do yourself a favor and find out the limits in your state for small claims court , in my state its $5000.00 before you need a lawyer, just your filing court papers may convince them to settle before a judgement is placed against them..again its your choice to go that route..just for argument sake, whats the bill from CAT going to be?..and forget about buying any other machine that someone says runs good, as others stated a seller isnt going to tell you it doesnt run good, and now your further in a hole with another broken machine...good luck with whatever way you choose..dont let this drag you down..look at it as an education and education costs...dont let it cost you with an ulcer or other health problems....Thanks for the encouragement d9,I really need support.Thanks again!!
