I have a 2006 d6 r series 2 that I purchased with some transmission issues. I replaced a solenoid in the trans that was giving me some problems and thought I had it fixed but the trans light has been coming on again and throwing the code 113.0673.02 I looked this up and it looks like a speed sensor code. The speed sensors were replaced by by caterpillar and the internal wiring harness was also replaced. Can someone give me some tips for troubleshooting this. Which speed sensor is this? what wires going into the transmission runs this sensor and can it be checked with ohm meter. Also which wires run this sensor that come out of the cpu and can they be checked with ohm meter or can I bypass the wiring harness and hook up to the transmission harness to see if the fault is from the cpu to the transmission harness?Is their any other wiring faults that can cause this code to show up. The transmission is working fine besides this fault showing up but I am afraid to run it because I do not want to tear something up. Any help would be appreciated.
