Hi all.
My 500 foot long driveway needs some work prior to winter. It has previously been covered with larger (probably 1" or 1 1/2") limestone which I hate. It doesn't smooth out well and with our drive having a couple of curves, the car tires tend to kick these larger rocks out the the edge.
I believe the answer is smaller material. Our old place had smaller rock chips which were packed tightly and didn't move around much. I have found two local suppliers that can provide 3/4- minus material. One place does limestone, the other crushed concrete. The crushed concrete will run my about $5/ton less. With an estimated need of 45-50 tons, thats a pretty significant savings.
I have a double drum roller which I plan to use to pack the new material into the existing drive to help smooth it and form a solid base.
Does anyone have experience with the crushed concrete? Will that do what I want?
Thanks!
Thanks!
